40s Tiffany Chronograph Info
Hey there!
I'm being offered this Tiffany-signed chronograph by Concord. It should be from the 40s, but don't have much more information on it apart from the following similar thread/site:
- https://wannabuyawatch.com/product/concord-chronograph-circa-1940s/
- https://www.watchuseek.com/threads/fs-vintage-concord-chronograph-sold.3640618/
I am attaching some (really bad) pics.
Does anyone know anything about it and/or possible value? It would mean a lot
Regards!
Welcome
Do you have any really good pictures?
That mov't pix shows as it would if I'd had 4 Scotches, but I've only had 2........
Welcome
Thanks!
Unfortunately, not much better ones. I have another one which is barely visible. I'll ask for more...
Case size?
Seller says 33mm, but the similar example from wannabuyawatch says 31mm... So, on the smaller side.
I would guess that 33 mm is approximately correct, as the movement (Valjoux VZ) is around 29.5 mm in diameter.
33mm is going to limit the value, and the condition is just fair. It's an interesting watch, but I would be careful paying too much for it. Old chronographs can often be a bit of a money pit for repair (I'm seeing a lot of corrosion/oxidation) and it won't be easy to sell. I could see risking maybe $500 on it.
