3861 initial thoughts...
One Q - is the movement in this model Moonshine gold? I thought that was only for the full-gold 50th model, no?
Looking at the Omega web site, it shows the rhodium version for this watch.
Good post. I know I am probably in the minority but I will be happy to stick with my 1861.
There is zero evidence to suggest that one or the other will be called "3861M" in any official Omega documentation. I'm going to suggest it's not the Extranet that is misleading here.
https://www.omegawatches.com/media/pdf/watches/product-sheet/gb/en-gb/31020425001001-en-gb.pdf
https://www.omegawatches.com/media/pdf/watches/product-sheet/gb/en-gb/31060425099001-en-gb.pdf
Bunch of misleading 'bastedzz' now aren't they 😉
Search for "3861 msg" - results - "No result found"...
Search for REF 31060425099001
000 MATERIAL: Gold Other / Métal
Calibre: 3861
In collection: YES
qty limited series total: 1014
No Monosodium Glutamate mentioned...
I love reading these, even if I do not understand half of it yet.
Thanks,
Alex.
Thanks for the detailed and informative post! So for a relative newbie who is finally ready to splash out on a Moonwatch and based solely on movement considerations, would you recommend that I pick up the current 311.30.42.30.01.005 with the 1861 or wait a revised model with a 3861?
Lots of highly technical information that goes completely over my head. Similar to the technical information on the new mid-engine Corvette that I recently read...all very nice, but here's what I got out of it; 490 horse power and 0-60 in 3.2 seconds. Barrels, co-axial, escapement, jigawatts, flux-capacitor...does the watch keep good time? That's all I need to know. 👍
You're not alone, I am more than happy with my 1861
There are many threads on the topic of co-axial vs. conventional Omega movements. Here is one:
https://omegaforums.net/threads/co-ax-vs-non-co-ax.43575/
Thanks. I'm still trying to figure out how to efficiently use the search function...
Sometimes it can be better to use Google using site😲megaforums.net to limit the search.
Edit: sorry, I tried to type ": o" without the space, and it converted to that smiley.
I read the post 3 times and my head is still spinning .. my respect to a true master
Oooooh, so we finally have a Speedy Professional movement that hacks?
I didn't notice it hacking, but I'll check and confirm when I get home later
Surely 'msg' = Moonshine Gold? 'O' I would guess designated 'oro' or Sigma. Makes sense to use the shorter term in technical papers, etc.
Indeed, the normal, assumption for MSG would be MoonShine(TM) Gold... but this comes from an English version of marketing tool, so it may not represent the official name as per Omega’s part number list... as indicated by Al.
O would stand for Or (French word for gold)… just like OM on the dial of the original 1970 BA145.022 (OM SWISS MADE OM) stood for Or Massif (ie, solid gold)... which on the 50th anniversary version could be equated to Or MoonShine(TM)… Et la boucle, est bouclée!! 😁
Yep, it hacks. Totally missed that when I first wound it up and set it.
