1991 Omega Speedmaster 3590.50 - Need a 1479 812 bracelet!
I believe those long S dials were around in the late ‘80s so your watch could be from 1988 or 1989 and still be sold in 1991. I hadn’t noticed before that your one subdial hand was loose in the case and the crystal is cracked. Nothing that can’t be fixed but I just hope there isn’t any significant damage that the seller didn’t report. I’d avoid getting it serviced by Omega because they’ll likely give you a service dial and hands
I saw the hand floating around when I bid and the incorrect bracelet. He doesnt mention it in the listing though.
Uncle seiko endlinks are a perfect fit out of the box for these Speedy Pro’s. It’s when you try to put them on a different model that they need some tweaking- but I have a US flatlink on my Tissot chrono and it was near perfect out of the box. I also own two of his Holzer bracelets.
I have the original 1171 that came with my Speedy- I prefer the US bracelets. If you have money burning a hole in your pocket- go ahead and get the correct factory bracelet, but I think the US bracelets offer more bang for the buck.
Its good to know this its original dial from the late 80s early 90s, fantastic
Going independent is no longer a possibility but a certainty. I have had two Seamasters uttery fail after being sent to the omega service centre in the past 12 weeks.
I sold one and I was just told the crown and winding stem came out. My seamaster 2531.80 was returned with a clasp which worked as a handcuff. I couldnt take it off again. Also on a full wind it stops overnight.
I want this speedy serviced correctly.
Your dial is the same as my 145.022 serial 48274408, which ilovemyspeedmaster dates to May 1991. Mind you the only way to be sure of actual production date is to get an Omega Archive Extract. There is always going to be some transition between executions, with watch production older parts are always used up before moving onto new, it's a business after all.
Vintage Heuers are a minefield like that, you often get watches with a mixture of dials and hands as parts crossed over in production. I have a Carrera 1153N bought from the original owner who never had it serviced. It has first execution hands and dial, second execution bezel and Calibre 12 not the 11 as you would expect. Does not fit either execution but it came out the factory that way.
Here is my 48,277,XXX which the extract shows is from July 1991
So if mine really is May 1991, which your serial would appear to indicate is true, Speedmaster dials were changing over from the long S and R in 1991(ish).
Thanks guys, that sounds right to me. Rolex did the same thing in 1974 with the 1680.
Thanks, sounds right and my warranty card is dated 1991. Well when it arrives I will check and confirm the serial number. I will update you all then. This is definitely interesting and when I bought the watch I am sorry to say, I didnt notice the difference in the dial text until afterwards.
FWIW I would not be let it bother you, the long S and R text I reckon dates back at least to the late '70s, gives a little more vintage appeal to me.
Below is the dial on my other Speedmaster, a 145.022-76 produced late 1976.
I am actually really happy I accidently stumbled onto the last of the long S and R dials. In many ways I am such a rookie at this still. Very nice watch indeed 😀
Omega have offered me a brand new 1171 bracelet as a part of the service. Still considering if I used them or go independent
It's your decision, but risky with regards to the hands and dial. BTW you can buy a bracelet from Omega without having to get a service done, so unless they are offering it to you at no charge, this is no deal...
Does omega swap out dials during a service?
From some of the feedback I've seen, they often do. Their goal with service is to hand back something that looks as new as possible, which means you risk the dial and hands being replaced with service parts, even if you explicitly tell them not to.
Have @Archer service it, You will get a service better than Omega at a much more reasonable price and he wont fυck up your watch with something you dont want as Omega does.
FIFY
The aftermarket bracelet looks good, IMO. I think Omega boutiques offer a free ultrasonic bracelet cleaning. Alternatively, you could put it on a strap.
My 3592.50 has long S and long R. That model wasn’t produced until the very last couple years of the 80’s. Mine is from 1991. I’m not sure if they used the older dial on these models but mine definitely has it.
Well its finally here, that took a while. The serial starts with 482, so thats 1991. Movement appears to be locked tight, the bottom chrono button is jammed.
