18mm 1960s Omega buckle
Hi all,
Looking for an 18mm Omega buckle for a 1969 Constellation C Shape, like the one below. Thanks!
If anyone’s looking for a distraction today and wants to check through their buckle stock...
Bump. And for clarity, looking to add this to a 20mm strap, so looking for a buckle with an inside measurement of 18mm. Thanks!
I think the C-Case Connie using 19mm strap, and 16mm buckle is correct for it 😁
You are 100% correct, only problem is I have a 20/18 strap I LOVE on the watch so was hoping to make it work... but if no luck I will look to pick up a 16mm buckle for sure.
Have you consider buying it brand new to your AD? It cost 50€, same as the vintage, easier to find 😀
I have a 16mm steel vintage buckle ?
I appreciate that. I actually have one similar, that's from the 50s, was looking to get real OCD and go for the style from the late 60s to match the watch exactly. So will use my 50s style for now, but still open to the one above if anyone has.
I love the hunt of vintage! And getting the exact style from the 60s, but appreciate the message.
