Yea
I live on the granite island. Highest cancer rates in Europe due to Radon.
Yeah, Radon is an Alpha particle emitter with no stable isotopes and denser than air. Its the biggie in the cancer stakes. Nasty stuff.
And the decay products are all nasty too, so you inhale the tasteless, colourless, odourless gas, it does some damage and starts decaying and the decay products are solids that stick to dust particle and the walls of your airways and stick there and continue doing damage.
The alleged Russian assassination of Litvinenko used Pollonium, also an alpha particle emitter.
Alpha particles are helium nuclei, so massive compared to beta particles which are electrons
That's why they are so dangerous - small enough to get through cell membranes, big enough to hit atoms in molecules and disrupt them, like DNA
Tritium on the other hand, as I mentioned earlier, emits beta particles, And these are of a particularly low energy, so have little penetrating power. Not to say they can't do the molecule smashing, just that this requires a LOT of energy for an electron to pull off.
This isn't bias or lobbying. This is physics.
They won't penetrate more than 6 mm of air and are stopped by skin.
As mentioned previously, regularly consuming a level that is a hundred times higher than that allowed in the US will raise your dose by one fiftieth of the dose deemed safe for workers in nuclear reactors, x-ray rooms, or working with isotopes.
This is about one tenth of the dose of the normal background radiation level if you are just chillin' in your house, even less if you're on a flight.
So that is around a 500th of the average dose.
Tritium, unlike Pollonium or other heavy metals does not accumulate in the body. Of anything.
Tritium decays to create helium, which is inert and the aforementioned beta particle. That is it.
So fish swimming in a lake, Great or otherwise, will not accumulate tritium.
Unlike heavy metals such as lead and mercury which are just toxic chemically, or radioactive nucleides like uranium or thorium, that decay to create alpha particles ( those are the nasty ones from above) and Radon Gas ( the nasty stuff that kills folks)
Again, this is Physics that is quantifiable by repeatable experiment.
So on to ALARA, which is not about not x-raying your ankle if you are having a heart attack.
In fact, the opposite is true
If you trip and fall, the risk to your life is low. Therefor the risk introduced by imaging your ankle should be similarly low, unless there is reason to believe there's something else wrong And in the course of taking those images, the x-ray radiographer will only take those views thaat the doctor asks for or that their training shows will best show the location of the break. They won't keep snapping away until they get the perfect shot. Also they will use settings that will just barely give an image. But they will take a series of images because they can't fix it unless they can see where it is broke.
However if you were to trip and break a rib, as long as you are not exhibiting symptons of puncturing a lung, then they won't x-ray usually. There is so much connective tissue its not going to get displaced and there's no treatment other than time, so why dose the patient for no improved outcome?
However, If you are having a heart attacak and the cardiologist is trying to save your life and insert a stent, then the risk to your life by not know where the catheter is going is huge. So a few years ago this would have been done using a flouroscopy technique that on average used a total of a 21 minutes exposure. This is equivalent to about 150 years of normal background radiation. This is a huge dose and it increases the risk of developing cancer later. However the risk of
not doing the imaging is that you won't have a later in which to get cancer. Similarly, the age of folks who do end up with this type of procedure often means that they may not end up living long enough to develop a radiation induced cancer.
Modern digital detectors have improved this enormously, but it is still significantly more than almost everything else you will experience in your life.
Its also interesting to note that cancer is not a causally linked outcome to this level of radiation exposure. It increases the statistical liklihood of some cancer occurrence at some point in the future, but it is not an "if a then b" thing. Its an "If a, then, there's a greater than x% chance of b"
Its not like Cyanide, where if you consume the requisite dose, then you die.
There are still folk around who survived Hiroshima and Nagasaki and are cancer free. This also makes those Radon-Induced cancers really hard to count - that's why they are estimates based upon all other factors being equal, genetic, environment lifestyle etc, etc.
I'm not trying to say that environmental damage is nonsense. I'm not trying to say that big business doesn't do things that it shouldn't. Nor should you go dancing around in a disused uranium mine for kicks. What is done about previous mine remdiation doesn't have anything to do with the production of Tritium either.
All I'm trying to say is that radiation isn't a single thing and it doesn't have universal outcomes. I've never called anybody stupid, just that folks who don't understand the different types of radiation, what they do and how they behave always tend to react fearfully.
Tritium is a relatively innocuous material in the grand scheme of things. Even the above rough conversions are a bit iffy as the dose equivalents are really dependent upon the type of radiation.and the particle interactions
@Archer - I'm glad that you are around after your stent to love your lakes - yes they are spectacular as we saw in our trip to Canada after my wife had a brain aneurism fixed with a stent & balloon under fluoroscopy, so I'm real familiar with this, quite apart from working with the equipment.
Also worth bearing in mind is that even if Nuclear power wasn't around, we'd as a society still want reactors for all the isotopes they create. Ever had a friend of relative with cancer given a treatment involving radiotherapy - from a reactor and it has to be relatively nearby as the isotypes used will usually decay in hours or days. Even eaten packed chicken and not choked on a foreign object? Radioisotopes are routinely used in food processing to x-ray food to detect foreign bodies, the list goes on & on.
I'm glad to hear that your relevant goverments co-operating can achive desired outcomes. I'm just nervous when I hear about legislation and there's no mention of any science being done to validate it. Happens here in Australia all too often. One of our former leaders thought that Wind Power was ablight on the landscape and should be banned and started down the path of this based upon, well nothing but funding from a lot of coal mine owners, really.
Besides, watches with Tritium dials and hands are
so cool, I'd hate to see them banned.
