SerP
·Hello gentlemen, I need your help..
My question is about well-known model of Seamaster 300 - ref. 166.024..
More precisely, it's about "Big Triangle" calendar variation of 166.024: please tell me, what is correct case ref. for "BT"?
As there were several case options of 166.024: 166.024/166.024 SP/166.024 SP2, (perhaps some others?) not all of mentioned references has been used for the "BT" with calendar. So, what it is correct case Nr.?
It's also a lot of "franken-watches" in the net, which has been assembled as is, also fakes, so it's hard to find-out what is what if you are not specialist..
Am I correct that the only case Omega officials can currently offer (if to ask them about 166.024) is complete case with code 166.0324, which is incorrect to use with the Big Triangle dial..?
Thank you in advance for your time and your attention..
