What do you listen to your music on?
Yep yep, completely agree, I nearly bought some the first time around but at the last minute swerved to Sony instead. I did find I detected more of a 'pressure' in my head when the noise cancelling was on with the Bose than the Sonys, I'm guessing this was them working better?
I think so. I tried a pair of Sony first and found they didn’t do much. After seeing majority of frequent flyers wearing the Bose and reading about them, I gave them a shot and was impressed by the virtual ‘vacuum of sound’ they create. I am very sensitive to sound and so by adding a low volume music track to the noise reduction effect I find it much better to shut out the world.
I can handle the pure sound of flying, but the d*mn people they let on the plane with me can drive me mad.. 😉
(Worst is the clinching of silverware on dinner plates when you’ve said “no” to the meal so you can sleep instead... and then you spend an hour smelling delicious food and hearing others enjoying their meals with ever ‘clink clank’... oh to fly private!!!). 😎
delicious food
Either you actually did fall asleep and were dreaming, or you fly on an airline I have yet to try. 😀
Last bit of Arcam gear I have left...FMJ DVD player...
Started out with the Delta series, then had an Alpha 9 CD player (which was excellent until the transport died) and along the way some other like an Arcam Diva AVR300 receiver for my surround set-up.
....(Worst is the clinching of silverware on dinner plates when you’ve said “no” to the meal so you can sleep instead... and then you spend an hour smelling delicious food and hearing others enjoying their meals with ever ‘clink clank’... oh to fly private!!!). 😎
I find a healthy dose of Malbec takes care of that.
We need to talk....I need to copy all my CD's on to something and have no idea where to start. Read about NAS drives but no idea where to go next.
[Edit] The only thought I had was to buy another decent CD player, not sure if that may be viewed very retro in a few years time...
Happy to help. It’s remarkably easy and once you go there you wonder why you didn’t do it before. I love streaming because I can spend my limited cash on better speakers and an amp rather than a CD player, record deck, tuner etc all of which become redundant. My set up is now much cleaner and digital to analogue conversion happens much closer to the power stage so sound quality is just incredible.
The basic concept is simple. Music is stored as data and streamed (or cast) to the device. This is a bit of a misnomer as the device has to read the library and request that a file is streamed by the server. If you centralise the data and make it available, it can be streamed to several devices at once, or conversely, much more music can be stored in a single library. The device in question can be as simple as your phone / tablet / smart TV, or something hybrid like an apple TV, a dedicated audio device such as a Chromecast receiver, Sonos, Google Home, Apple Homepod, or even a high end hifi network streaming device. All do essentially the same thing - read the library and request / retrieve the stream. Some will convert to analogue, others (high end particularly) might only have a digital out for feeding a separate DAC stage.
You need:
1. A NAS to hold your music collection if you have one. Get a fast one. I use a QNAP TS869 Pro but would recommend a TS453 Pro right now. Fill it with cheap SSDs. You can configure the SSDs to behave as a single logical drive using something called RAID. For backed up SSDs you can use RAID 0. For regular spinning HDs use RAID 10 for redundancy. Then figure out how to back it up, typically to an external 3.5" drive which you can keep in the safe. If you only have only one listening room and a USB port on your amp you could also use an SSD in a USB enclosure directly connected to your amp.
2. Streaming. Stream over WiFi or wired. The beauty of the setup is is that you can access all your music anywhere on the network, simultaneously. So you need one or more client devices. For the NAS solution you'll need a server application (software on your NAS to share the library). I use Plex but there are lots out there and they're all free.
3. Ripping and adding meta-data. One word, lossless. AIFF, FLAC or ALAC will be fine. It's tedious to do but only needs to be done once. EDIT: Some lossy formats such as 320kbs MP3 are also more than fine.
As important as sound quality is being able to find your music easily. Organise your files in folders by Artist, even though your server streaming software will likely ignore it, Instead they read individual file names and organise the songs itselg. Files use ID3 tags (meta tags) to store all the associated information necessary. This isn't just Artist / album name / song title, but cover art, genre, release dates, collaborators etc. CDs contain very little of this data digitally. But there are tools which work a bit like Shazam in that they will scan the song and write the meta-data.
Are you Mac or PC? I’m a Mac guy and I use filebot, songkick and Metaz to enrich metadata.
The more time you spend with meta-data the better your search experience will be so it's worth investing time.
4. Additional streaming sources. Depending on your preferred music genre there are several cloud based streaming services available to you. Spotify, Tidal, Apple music, Google play which will invigorate your listening and expose you to more music than you can imagine.
Many (young) people these days don't own their music so skip steps 1 & 3 and just stream a cloud service to their phone and then bluetooth to a speaker, or perhaps use a chromecast connected to a decent amp. Results are superb. Even if you're married to your vinyl it makes no sense not to spend £35 on a Chromecast audio (or a bit more on a decent bluetooth receiver) and plug that in to your 1970's beast of an amp, giving you an extra source of music.
That's it! If you decide to move your digital files to a NAS you can of course ditch all the CDs, the CD player and probably a bunch of wires.
There will be naysayers and each to their own but y'know, people used to listen to music on cassettes or reel to reel tape and they don't any more. It's the future 😀
Thanks v much for the detailed walk thru. Shall digest tomorrow whilst browsing for drives. I love the idea of getting shot of the cds, however am now torn with the idea of buying a top end player / streamer ( as above). Need to mull it all over.
[Edit] the context of all this is me going back to solid state media. My current set up is a big Sony AV and Q Acoustic floorstanders , all on the network, with Spotify at being the main source. Prior I had a chunky separates system , with 70s Pioneer amp.and NAD 5120 turntable.
+1 for QNAP...
I recommend a wired set-up - that's what I have.
For ripping I used dBPoweramp CD ripper, and everything to FLAC files.
I also stream using Tidal - for me well worth the money each month.
Hi guys
Funny topic as I am setting up at the DC AUDIO SHOW!
I am working with Ohm .... anyone coming by ?
Best
Bill
Actually reel-to-reel is making a comeback. Just sayin'...
I am trying like heck to work it into my schedule. I wasn't able to get there last year. I'm on the hunt for both streaming and analog equipment.
So is cassette...
Nooooo! Although my holy grail at the thrift store I frequent is a Nakamichi Dragon. Or UDAR..
So is cassette...
...my holy grail at the thrift store I frequent is a Nakamichi Dragon. Or UDAR..
You goddamn hipsters with your magnetised sellotape, frisbees with grooves cut in them and your wax cylinders 😝
Hipster? Errr...okay....🙄
Exactly - solid state has much less to go wrong. Hit me up for a chat if you have questions
A couple of Sonos Play3s.
Sound great.
Use to runs a Rega Planar 3 on Mission 770s.
Got to say I love the convenience of the Sonos and the minimal space, but miss my LPs.
So is cassette...
The cassette player was the one thing I pulled from my system this past year. And the other night my 5-year-old had me bring it back upstairs and show him how it worked. He is taking a keen interest in it. I hope he develops a taste for ska, as a lot of my tapes were made by a British friend of mine in the early '80s and he was fond of ska bands 😁
But yeah, cassette is, in fact making a comeback at my house.
Hi
I have 5 systems.
Nakamichi SR-4A
W PolK speakers from the 1980s I think thy are RTA-12
Using amazon dot as digital source ..... for my brother
Marantz 2325
W 2 pairs of McIntosh XR-5
Schitt Audio dac / oppo cd / Bluesound node2 , my office system
Carver m1.0t driving Dq-10s
Another carver m1.0t in mono mode driving Dq-1w. Dq-lp1 for crossover
Node2 , and a dot for digital sources
Home system
Outlaw 2160
Ohm Walsh 2
Back office
McIntosh solid state receiver can’t remember model old one from 70s
W DQ-30i
W ECHO DOT SOURCE...
AND THE BEAT GOES ON...
BILL
