The Omega seen in the picture has been found as part of an estate. It is in bad nic, so probably not worth any effort, but it has me stumped as to what it is? Anyone know.
1940’s style. Probably a cal. 30 series movement inside. Looks like there is a little wear-through on the lower right lug, so I would guess that it is gold-plated.
gatorcpa
The movement appears to be is a 30T2-SC. If the movement is running this on its own is worth a little bit for parts. But if the case is solid gold and you've retained the caseback then it could be a nice project watch for someone.
