Trying to decide between SMP and Heritage summer blue
I am looking into getting a summer blue sea master but really can't decided between these 2. They are both beautiful in different ways. Overall I think favor the heritage a bit more. But seeing some photos online, the dial seems to be a lot lighter blue than I was expecting. Any input would be appreciated.
For additional context, this will be my second omega. I have a 42mm planet ocean, black dial.
considering you already have a PO, IMO the Heritage would make for a more distinct addition to your collection
Tried some of the Summer Blue collection on at the local OB when they were released. (AT, SMP, Heritage, PO) Both of those are pretty close, fall into the middle blue shades. Reason it looks lighter in general is the sunburst graduation from the center. The caseback is definitely a beautiful piece of art.
Either will be good since your PO is a black dial. The Heritage has a different vibe than the SMP and if you're looking for something different, that's the way to go.
Thanks for your response. Yeah I too think the heritage will be a good second omega for me. I think I will go see one in person to make sure I like the color.
Yeah, definitely need to see it in person. They look different than the release pics from Omega. Probably would've picked one up if I didn't buy a new watch a couple months prior.
I can tell you that my Summer Blue can go from a light color to dark depending on the lighting, etc. I love my Summer Blue and I think you would not regret owning one. I also ended up purchasing the two-piece rubber strap with the fold-over clasp. I also love the watch back it's really special.
I’d go the heritage Seamaster 300, it’s a distinctly different style from the PO with an exposed crown, no date and a more dress watch feel which makes it rather convenient as well as quite a special piece. Rather thin too compared to other models.
Well.... it's wildly comfortable. The steel caseback makes it sit close to the wrist (and just over .1mm thinner than the regular heritage if that matters to you). It also has a nicely domed crystal; it's just not as tall as the on-paper measurement suggests. it's snug and tight to the wrist in such a great way.
the dial: while the SMP summer blue dial shows much of its color ability on a regular basis because of the flashier ceramic dial (which isn't bad) the varnished fumé dial here will make more subtle changes, but it can be dramatically different throughout the same say depending upon sunlight angles, cloud cover, how gray or overcast it is- the craziest dial effects are when it throws off emerald, ruby, and sapphire sparkles (which are essentially impossible to photograph) in shaded full sun. This dial is both dramatic and subtle at turns; like all of the summer blue series this is probably its greatest strength and greatest weakness. If you want a watch that consistently looks the same at any angle in any lighting condition, it is not for you. On most days this watch will not be the same in the morning, afternoon, and evening, and will vary appearance in different indoor lighting (a trait it shares with the SMP in some ways).
Timekeeping is exceptional, what you'd expect from Omega's METAS. Mine was 12 seconds fast this morning running constantly since February without being adjusted.
I've owned this for a year, and it is by far my most worn watch. I'm currently wearing a speedy on an Apollo flatlink (which I love) but I think the heritage flatlink is more comfortable.
I doubt I'll ever part with it.
Holy crap. Thanks for your insight. Can't ask for a better endorsement than that. I am gonna go see it in person, but I think I am now sold on the heritage. Thanks again.
I agree 100% the Heritage has a more dress look. You can't go wrong with it, but glad to hear you're going to check it out in person.
...Rather thin too compared to other models.
Probably the most poorly understood and most underrated thing about the heritage, is just how much of the height is in the crystal. Not quite vintage seamaster in height.
I'm curious as to what the caseback-to-bezel height is on the SMP; it's about 11.8mm on this heritage. Crystal takes it to 13.78, so ~2mm crystal height (vs 13.88 listed on sapphire display heritage, and the anniversary caseback varies by around .4mm down to 13.5mm thickness) I know most crystals, even flat ones, sit a bit higher than the bezel... Omega obviously has the boxed sapphire crystal that sits a lot higher and the Vintage Dome on the trilogy seamaster which is pretty tall... but --- I guess I would want someone with an SMP or an older flat crystal to chime in with measurements.
I love both of these, I think it really comes down to whether or not you like the design elements of the SMP like the helium valve, skeleton hands, and scalloped bezel, or the broad arrow, shark tooth markers, and 12-3-6-9 + coin edge bezel of the 50s/60s SM300. Can't go wrong with either one, and it's pretty easy to find things to prefer about one or the other.
I'm biased towards the vintage look and freely admit it.
I love both of these, I think it really comes down to whether or not you like the design elements of the SMP like the helium valve, skeleton hands, and scalloped bezel, or the broad arrow, shark tooth markers, and 12-3-6-9 + coun edge bezel of the 50s/60s SM300. Can't go wrong with either one, and it's pretty easy to find things to prefer about one or the other
💯 Perfectly stated
The dial of the 300 is a varnished dial, while the smp is ceramic I believe. Any idea if there are major differences in long term durability?
I doubt it- not much anyway. the ceramic dials are quite a bit thicker to reduce their fragility; as far as I am aware the heritage is a brass base dial (pretty common) that is very slightly "hammered" (like, with a hammer the size of a pin...) to give it teensy tiny bits of texture, and then whatever material creates the fumé look (on the entire line) is added over the top, it's spun (to make it lighter in the center) and then varnished. Basically, it starts its life off like most other watch dials.
When it comes to watches, varnish and lacquer seem to get used interchangeably. Many, many dials are varnished; the black speedmaster dial is varnished. Rolex dials are varnished or lacquered. Most dials- are varnished. Why Omega is choosing to play up this term in the case of the heritage (and white speedy) I can't say for certain- but using varnish on dials is not any sort of a new process, and watches that are 50+ years old still look great today (unless the varnish has been damaged by moisture or radium, or both). Most of today's varnishes are at least as stable as they were 70 years ago and probably more so.
There will likely be some subtle changes half-a-century from now in the heritage dial, but I can't say for certain what they will be.
Yea both dials are unlikely to degrade unless exposed to moisture, and in that case the movement will be at far greater risk than the dial anyway as Omega will have endless supply of spares.
Very informative. Guess I shouldn't worry about stuff that may not even have a significant effect in 50 freakin years.
