Tokyo Olympics...
Cool! I have to say his story is pretty amazing. Came back at 37 and performed admirably.
Interesting comment, and if I can possibly risk boring the hell out of you with an answer...
Olympic archery is a bit of an unusual sport, in that the bow hand has to stay very stationary, while the draw hand on the other side of the body is moving continuously during the shot. It may look in videos like they stop, but if they do it's sort of poor form - the shot should be one continuous motion. There is a device on the bow called a clicker, and the arrow goes under that little piece of metal, and when you draw the arrow through it, it will come to a point when it drops off the tip of the arrow, and clicks against a plate on the bow - this is the signal that you are at the right tension, timing, etc. and you are good to shoot. Not my video, but a good basic overview from Crispin himself:
This is with a bow that weighs maybe 6 pounds, but the draw weight (the tension on the string) when at full draw may be in excess of 50 pounds, held with just three fingers. It's very fine motor control of that draw weight and perfectly balancing that with the push of the bow arm that is the key. You don't really pull the bow with your arm muscles once you get past the very early part of pulling the string back, but with mostly back muscles, and by moving the scapula on the draw hand side, pulling those together and expanding the chest slightly. It takes tremendous strength and control to do it well.
So the difficulty, particularly mentally, is keeping that draw hand side moving at the risk of pulling the bow left or right, and the sight coming off the center. If you are near the part of the shot where the clicker is going to release, and the sight gets pulled off from the movement of the draw hand, the tendency is to stop pulling, which is very bad. I struggled with this hugely from a mental perspective under pressure, and I would stall out right near the point of executing the shot when the arrow was about to come through the clicker.
This is similar to the yips in golf when putting, and in darts they call it "dartitis" (not sure who thought that one up!), I think it's the yips in snooker, and in archery it's commonly called "target panic." It's the ting that any archer absolutely dreads having.
When I had that under control I was beating lots of people, and when it wasn't I was losing to lots of people. On the shooting line at most events, you have someone right beside you, and I had a very bad habit of shooting when someone else's clicker went off. Then at the Arizona Cup one year, and archer from Ireland was chatting to one of my team mates, and mentioned this issue. He showed me what hew as using, which was a "thumb clicker", so it was a wire with a pad on it the contacted my thumb, so when the clicker went off, it didn't make a sound, but tapped my thumb. There was a guy in Sweden making them, so I ordered a couple, and that greatly improved things.
So yes, it's very mentally demanding, and the people who are highly successful, like Crispin who has a bronze medal at the world championships, can control this far better than I ever could.
To add to this, most individual sports at this level have a huge mental aspect that is not really mentioned by commentators. Swimming, rowing and track it is pacing and knowing your race, shooting and bowls are probably similar to archery, muscle memory and mental ability..
Agree. As I am an amateur archer myself, I can fully understand.
At the highest level mental ability plays an important part in every sport. For some sports, where there are decisions to be made (usually because you have a direct opponent) it's about speed of thought, for sports where you are competing against a standard of some sort, it's about composure and mind control. I can't think of a sport that does not fall into either category.
Yes, there are "open" focused sports, and "closed" focus sports. In archery, it's mostly closed where you are working on your own shot process, and there are limited external concerns (rain and wind mostly). If you start thinking about what your opponent is doing, what score you need to win the match for example, you are already failing at the mental side, because that is just a distraction. Pretty much every archer at a high level will have a predetermined shot sequence that they have written down, and practiced tens of thousands of times per year. There are "go" and "no go" check at each stage during the shot process where you decide to carry on or abort the shot and start that process over. It's very methodical and repetitive, kind of like repairing watches.
I play a lot of tennis, and that is a very open focused sport. I have to think about what my opponent is doing, so where are they moving to on the court, where did they hit the ball to, the pace and spin of their shot and I have to react to that. Then I have to think of what shot I'm going to hit back with all those factors included, and then how I'm going to work the opponent to get into a position so that I can win the point. It's a very different way of thinking while competing, even competing as a club level player. But when doing all that thinking, you can't let the form break down, and that's mostly where I'm at as a player - being able to do all the thinking at once, because the form isn't engrained enough yet so that it's automatic. This is why I still have to tell myself to move my feet, and watch the ball.
Started watching the track events, so all I can say is go Andre! 👍
Well, Andre went! Won a bronze in the men's 100m, and just won gold in the 200, with the second PB and Canadian record of that event, and with a time that was faster than Usain Bolt's gold medal time in Rio!
Damien Warner is leading the decathlon, with another Canadian in 3rd, so that is going well so far. The men are starting to contribute to our medal tally finally.
We'll have to see how Canada can fair in the men's 4 X100m relay now...
Canada qualified to the final easily, and the US team has certainly lost their prior dominance in this event, completely screwing up their race and missing the final. Carl Lewis was not kind in his comments:
And a great day for Damien Warner, who wins the decathlon with a new Olympic record, and breaking the 9,000 point barrier! 👍
Also an alumnus, I was once named offensive MVP of our local flag football league. Don't remember my name being put on the sign naming me world's greatest athlete 😀
The American performance was shockingly bad, as if they had never practiced relays before. Happy to see Canada having such a good run in athletics - it's the 'old country' for most of my family, so I guess I'm a diaspora Canadian, at least for Olympic purposes 😗
Living in Maine, with a son who spent 5 years in college in Halifax (Kings University College), makes me part Canadian I reckon. Plus, my favorite watch maker is from there. So I am happy when our brothers and sisters to the North do well!
Well, Canada took the bronze in the 4 X 100m, and Italy "out dipped" the UK runner who thought he had it in the bag. Whoops! 🤦
And the goal of the Canadian women's soccer team was to "change the colour" of the medal, having won bronze in the last 2 Olympics. After beating the US to get to the final, they had to beat Sweden. After a 1-1 tie, two extra time periods, came down to a penalty kick shoot out. Gold is ours, and tough loss for the Swedes.
Congrats to Japan for winning the gold in baseball, defeating the US in the gold medal game. I'm sure that was a big one for the whole country! 👍
Cudos to France as well for pushing the US in the gold medal basketball game - it wasn't an easy win for the US.
Yeah, that basket ball game was closer than I thought it would be after the first two quarters.
Fortunately, we managed to win gold in volleyball AND handball!!!!! ::psy::
Thoroughly enjoyable two weeks of Olympic sport.loved every minute.well done Tokyo and all the competitors for keeping believing and delivering on what has been a truly memorable event.
Just watched the finals of the keirin race… and: 😲😲😲
Well done!! ::psy::
On the other hand, as usual, I will give a F to all American sports channel for always focusing on US teams and US-centric sports! ::facepalm1::
Every country's coverage is focused on its athletes and their sports, it's not unique to the US. Australian coverage was heavily focused on their athletes, and there isn't any guesswork as to what coverage in China was focused on.
NBC’s primetime coverage of the Tokyo Olympics on July 26 averaged 14.7 million viewers -- for a 49% drop compared to the equivalent night from the 2016 Rio de Janeiro Games and 53% less than the 2012 London Olympics. The opening ceremonies saw their lowest viewership since 1988.
doesn’t seem it’s having an impact on viewership anyway
Unfortunately missed most of it, just saw the Swimming and Gymnastic.
