The Turtle
That really turned out rather well. Amazing how well the appropriate bracelet works on these pieces.
When you have a moment, do you suppose you could post a pic of the endpiece? I believe that these NSA endpieces have no code on the reverse, so I'll have to find one by pattern recognition.
Hopefully these will show what you need Lou but if not, just ask and I can take some more:
You will also notice the absence of the Jaxa scars from the case. Service, fix (using the parts I supplied) and repair the case for £150. The whole thing owes me about £500, so I think I had me a bargain with (hopefully) 5 years peace of mind. I was prepared to spend that on the watch as it was.
Thank you. What does the front contour look like? Is it flat or curved across the top?
Try these. I have shot the same photo twice using different lighting angles. The curve in the top of the end piece basically mimics the curve in the case but undercuts the case slightly.
perfect, thanks!
