Steel bracelet for Omega Constellation 167.021
Hello again! Following your advice I have found another piece of 167.021 Connie which seems to be in great condition. I have set an appointment with the seller for today's evening. I now need your help with finding a fitting steel bracelet for this model. Can you please tell me which end links should I look for? Also can you confirm that the lug width is 19mm? Would you suggest looking for an original Omega bracelet or rather searching for aftermarket options? I will consider any bracelet models as long as they are steel, quality made and fit the watch well. Please share your thoughts and experiences. Thanks, cheers!
Hey Max! Thanks a lot for your response! Just to make sure: I can use bracelets interchangeably as long as the width is right and the links are fitting? Also what is your experience on the aftermarket bracelets? It seems that finding the 551 links might be a challenge. On ebay I found only one offer and the price is pretty steep (https://www.ebay.com/itm/203926174553). What places would you suggest searching? Or does it simply take time and patience to hunt something? Thank you : )
Of course you can use anything you like. There are many aftermarket bracelets out there, as well as places to search, but to keep your eyes open on ebay is never a bad idea. Yes, searching for special items may take time and patience, but if you find what you are looking for it pays off, good luck with your search and
kind regards, Max
