  1. cvalue13 Aug 27, 2013
    Gents,
    what's your assessment of eBay item 161088184958,
    http://item.mobileweb.ebay.com/viewitem?itemId=161088184958Purchases made through these links may earn this site a commission from the eBay Partner Network
    http://pages.ebay.com/link/?nav=item.view&id=161088184958&globalID=EBAY-USPurchases made through these links may earn this site a commission from the eBay Partner Network
    ive seen the watch in person, and the watch has an 861 and back case reads 142.022. Is this correct for he watch?
    Other thoughts?
    Thanks, Speedy friends!
    EDIT: I know my conclusion, but was hoping for unbiased input. Also corrected typo in model #.
  2. Kringkily Omega Collector / Hunter Aug 27, 2013
    Just a modified speedy pro. I don't know how he got the 3870.50 reference unless he knew it was such prior to modification. Otherwise a simple 3570.50
  3. Kringkily Omega Collector / Hunter Aug 27, 2013
    Or a 3590.50
  4. Kringkily Omega Collector / Hunter Aug 27, 2013
    If it is an 861 movement with a 145.0022 then it is a 1996-1997 3570.50.
  5. cvalue13 Aug 27, 2013
    your first post was my assessment; your later posts are why I ask around here - great info!
  6. pascs Aug 27, 2013
    3870.50 is just a 3570.50 but with a strap instead of the steel bracelet.
    The watch in question looks like a standard Speedmaster and fitted with the Mitsukoshi Panda dial. The asking price is quite high IMO
  7. Kringkily Omega Collector / Hunter Aug 27, 2013
    Well it is strange as the 3870.50 series came a little later as the deployant is more of a 2000+ item with the push button style as typically the strap version for the Speedy Pro pre-2000 were reserved for good variants. I just find it strange he would reference that model for his watch description. The 861 movement is tell tale of a transition if the 145.0022 caseback is original otherwise a 145.022 caseback would make it a 3590. I've seen 3570 with the tritium dial but with an 1861 before but not an 861 movement.
  8. cvalue13 Aug 27, 2013
    apologies, but it's an .022, not a .0022 - I was typing from my phone earlier and only bc of your post did I notice my typo.
    Ao, a 3590 plus a separate bracelet, given the person's apparent interest in mods?
  9. Kringkily Omega Collector / Hunter Aug 27, 2013
    Sorry my post above said good when I meant gold. Yeah probably his thinking well if it didn't have a bracelet then it might be a 3870 but it is a 3590.50. I like the mod which is around a 550 including labor mod. Although having the original parts would be helpful it is a little high overall.
  10. pascs Aug 27, 2013
    There appears to be no visible movement number on the case so I'm guessing this could be a pre '90's case or a replacement case?
  11. Kringkily Omega Collector / Hunter Aug 27, 2013
    The flatten ends of the back lugs suggest a more vintage piece or replacement case. A serial number would solve our questions :)
  12. pascs Aug 27, 2013
    This is my take on the same dial.......:whistling:
    [​IMG]
    cvalue13 likes this.
  13. cvalue13 Aug 27, 2013
    note that the it comes with inner and outer boxes, and manual, apparently, so maybe listing number came from the manual? Not that this is determinative. I didn't get to see these materials.
  14. cvalue13 Aug 28, 2013
    Picked up the franken-panda today.
    The box and manual (non-matching) were of no help. I re-confirmed that it's an 861, and with a #47,xxx,xxx -- and a 145022 case back.
    Omega Speedmaster 4.JPG Omega Speedmaster 2.jpg Omega Speedmaster 5.JPG Omega Speedmaster 6.JPG Omega Speedmaster 3.jpg Omega Speedmaster 7.JPG She's a wearer for a bit at least.
  15. pascs Aug 28, 2013
    It looks lovely :)
    If you dont mind me asking did you pay approximately the original asking price?
  16. Hijak Aug 28, 2013
    I know its a franken and all...but just love that dial!:thumbsup:
    pascs likes this.
  17. cvalue13 Aug 28, 2013
    This was local for me, and I have a relationship with the seller. So, no, I didn't.
    Also, this seller deals in a lot of very high-end watches (aside from what's put up on eBay), and knows a good bit about all valuable watches, but not a ton about any particular brand. So, after a little education from me about this particular watch, I'm confident the seller would have subsequently adjusted the eBay description (and likely the price), had I not spared the seller the opportunity.
    If ever any of you see something from this seller you are interested in, I'm happy to take a look at it for you.
  18. ulackfocus Aug 28, 2013
    I like those panda frankens. :thumbsup:
    Who was the seller?
  19. pascs Aug 28, 2013
    This is what makes the Speedmaster so versatile, you can take a standard Speedmaster, add a new dial and hands and create something very special :thumbsup:
  20. Taddyangle Convicted Invicta Wearer Aug 28, 2013
    I modified my 3572 when I had it serviced. Well worth it.
