Some inaccuracies in that article...
First off the claim that "Most people use an independent watchmaker who will simply replace the chronograph module, rather than service it." This makes it sound like you can call up the local "Modules-R-Us" location and get a 1/2 dozen DD modules for servicing those reduced watches at the drop of a hat. Not the case at all as Omega doesn't sell modules for this purpose. What happens in most cases is that the independent watchmaker services the base movement only, and doesn't service or replace the module...they just remove it, set it aside, and put it back on after servicing the 2892 portion of the movement. You are typically only getting 1/2 the job done in these cases. Although there are people who will service the module, they are not around every corner.
Second, the author is grouping the "reduced" models with the "automatic" models, at one time saying this:
"The modern iteration of the Reduced / Automatic is called the “Speedmaster 38 Co-Axial Chronograph” and this "The modern version of the Speedmaster Automatic (Reduced) can easily be identified by a date window at 6-o’clock."
The Speedmaster Automatic is not in any way the same as a "reduced" model, as the Speedmaster Automatics use some version of the ETA 7750 in them, which is a fully integrated automatic chronograph, not a modular chronograph.
I would take information on blogs like this with a grain of salt, since most of the people writing these blogs don't have a lot of technical knowledge.
