Space-Compax Rubber Pushers: Maintenance
Hello, all you Space-Compax owners!
For all of you lucky enough to have a Space-Compax with original rubber pushers, what steps do you take, if any, to protect or restore the rubber?
Any rubber will deteriorate with age, so there are rubber-conditioning products available, mostly for automotive uses. Do you apply any of these to your Space-Compax? Do you apply any homemade solutions? Or do you just keep them clean and minimize use?
Thanks for the input!
If memory serves, @Diabolik is the resident guru on all matters crown and pusher-related on the Space Compax.
Sorry I can't really help beyond that but good luck.
I appreciate the suggestion, Woops! I reached out to him.
Can't say if these are a good alternative or not but they are an aftermarket replacement that may workout if you decide to store and preserve the originals.
https://www.ebay.com/itm/401597867969?hash=item5d811927c1:g:h48AAOSwQz1bK1mH
Not a bad idea, Watchcollect! I have looked at those but the pricing is outrageous for a couple pieces of small rubber. But not much choice if you have this watch and need 'em!
A collector told me I should used olive oil, could work for hardened rubber tops.
Many thanks! I had not thought of that but it sounds reasonable.
