Waltesefalcon
·Today my Hamilton measures an 1 1/2" by 1 1/8" and that is just fine for me.
I generally prefer 38-40mm, but it really does vary from watch to watch. More important to me is the lug-width, which can change the entire feel and wear of the watch.
As an example, take a vintage 145.012 Speedmaster at 42mm vs. a Longine Legend Diver at the same case size.
Despite both watches having the same case size (42mm), the Speedmaster has much shorter lugs and wears much smaller. In contrast, the LLD has a much longer lug-to-lug measurement and feels like it overhangs on my wrist.
One of the earliest lessons I've learned in this hobby is to try on as many watch types as possible. Get a feel for what works and what doesn't. Otherwise even if you get a great deal on a rare watch, you'll find yourself putting it in a safe because it just isn't that comfortable to wear.
I agree, here are the other important factors affecting how big a watch looks on the wrist, other than case diameter...I’ve thought about this a lot so forgive the minutiae.
1. Bezel width (wider bezels make the dial look smaller and hence the watch looks smaller).
2. Case thickness (thicker makes the watch look bigger)
3. Lug length
4. Lugs that curve downward (make the watch look smaller)
5. Black dial or bezel I think makes the watch also look smaller while white dials look bigger.
Interestingly, I haven’t found that chronograph pushers actually make a difference, my 35mm chronograph still looks the same as my 35mm dress watches.
Ultimately you have to just try the watch on bc there are so many variables at play.
From 1930's 33mm to 2018's 43mm, watch size keep getting bigger and bigger.
What's your favorite watch Size? And why?
I will start, for me 36mm to 40mm are within my comfortable range. Anything above are just too bulky and not comfortable.
