Should I get my PO pressure tested?
Thanks for your respected input and yes I do understand this. I personally am of the opinion that a modern gasket that must be EPDM or similar should last 10 years yes. The fact that it has now passed to 300m gives some reassurance that it should be ok for another couple of years or so at minimal free diving depths. I'll probably look to get it re-tested next year.
Not EPDM...NBR.
Hey it's your watch, and you might get lucky. 馃憤
In forty years of commercial and recreational diving I have never had a dive watch leak. I did however have a Citizen watch supposedly rated to 100M crap the bed on a series of fifteen 100 foot dives. I do not think a watch like the PO needs pressure testing every year, especially since you are only going to 75 feet or so. However, regardless of what the service center says I think eight years is pushing it on seal replacement. I work on a Submarine that regularly dives to about 100 feet and all of the seals are replaced in less than a three year period. Some as often as every six months. Good luck.
It will always be difficult to convince some people that this kind of maintenance of gaskets is required, until they have an incident themselves.
The reality is the parts that fail, the gaskets, are no different in a PO than they are in a watch rated for 50m. The fact is most failures happen with no real pressure - washing hands, dip in a pool, etc. People seem to believe that if a watch is rated to a very high depth rating, that it won't fail at lesser depths, even when the seals are not 100%, and this could not be further from the truth.
My 2500C is 11 years old this year, It's only been serviced once. I had it serviced at Omega about 6 or 7 years ago, when the full service was still 拢300GB. It's running great at the moment, do I really have to send back again now do we think, It doesn't see much water at all, if that's a factor, but in your professional opinion, is it long overdue now, despite that one service?
Here's what Omega says now...
Here's what Omega said last fall, before they announced the change in warranty to 5 years...
What changed about the actual watches? Nothing.
So the watches went one day from needing service every 4 to 5 years, to the next day miraculously only needing service every 5 to 8 years.
What is really needed? Based on this, your guess is as good as mine. In my experience, going past 7 years is certainly risking damage to parts, and in fact I've seen 5 year old PO's that the movements was completely messed up inside. Now does that mean you should service it? It depends on what you value and when you consider the "need" for service to be.
Simple question...complex answer...
watches? Nothing.
It's very possible I'm missing a nuance here, nonetheless: for the sake of argument, let's say a company is accumulating data on wear patterns of parts, and how that relates to service intervals. At a certain juncture, if they feel they would have enough evidence to make a policy change, why, theoretically, would they have to change the watches to change the policy?
Sure, that's probably it right there...
So to summarize for someone who relies on an expert opinion as far as best practices to avoid inadvertently damaging your watch:
1) Get pressure tested yearly
2) Service every 4 years
Archer, would you say this is sound advice or your recommendation?
I see your point! 5 to 8 is such a ridiculous thing to say anyway, on their part. It's far too broad, a 3 year difference doesn't tell us enough.
It should be 5 or 8.
Thanks for your response
You should probably follow this. Here's why: you should be aware, that as a company, Omega have no competent watchmakers to accurately assess the wear to their watches when they come in for service. And, apparently, even if they did, they could not legitimately make a policy change on service intervals to their watches unless they made a corresponding change to the watches themselves. In other words, if the bulk of watches that came on the previous, shorter service cycle showed less problems or wear than the company originally anticipated, since they didn't change anything to the watch, these observations are void.
And, since it's been said many times that Omega exist to satisfy their shareholders, if they extend the service interval, they would ultimately be getting less revenue, not more. Thus, we are left with the conclusion that Omega extended the service interval with the hope that the owners follow that, wear out their movements, and can then reap that lost revenue by hitting the owners with part replacement costs.
That's probably it right there...
Omega charges the same price whether they replace no parts or 30 parts. They charge extra for new dials, cases, sapphire crystals etc, but the internal mechanics have always been included in their service fees.
If this is indeed the case, then they are on balance making less money recommending less frequent service. I'm going to believe the extended service change by the company is based on something substantive. Perhaps it's more attractive to new potential buyers.
Or, Omega wants us to wait long enough for a service that it's guaranteed to need parts, and so we'll have to send it to Omega for service instead of an independent, since Omega includes movement parts with the service.
Guess I should have waited to finish reading the thread before posting something for the hundredth time...
Interesting. I certainly have read repeatedly that vintage watches of any value should never be sent to Omega. But if given what is apparently the policy that, if you send your watch to the company for service, you are not charged any more for additional internal parts, then really, with these new watches, what's the big deal if you wait too long to get your watch serviced?
All I can say is these watchmakers must be very good to be able to observe that parts on a watch movement that is so new it hasn't even been in service in any watch for 3 years can last 5 to 8 years between services! I guess they must have their Bergeon crystal balls calibrated very well indeed...
Or we could observe that when Omega increased the warranty period on all watches to 5 years, it didn't make any sense to recommend servicing every 4 to 5 years, so they really had to extend the recommend service interval for it to make any sense. We can conclude that someone has made a marketing decision, and the company has run the numbers and found it won't have a significant negative impact on the bottom line immediately, and by the time it does service prices will rise enough to cover the additional expenses they might incur.
You can certainly chose to believe one or the other, but I know where I would place my bet...
That could be it. As I mentioned before, I think consumers find a company extending a warranty period attractive. I, for one, certainly like the sound of 5-8 better than 4-5. Omega is a big company; maybe the marketing people found that the shorter service interval period was an impediment to new sales, extending it was more attractive, and the change has nothing to do with the watches per se.
On the other hand, maybe there is some relationship between extending the service intervals, and the watches themselves. I get your point about the new movements being too fresh to observe wear. Yet, a lot of companies do on-going, in-house reliability and wear testing, so maybe Omega do this, and found their movements held up better than expected. Obviously, just a postulation.
So here's a real situation - customer of mine who I serviced a watch for years ago needs it serviced again, but I'm too busy. He emailed me yesterday to let me know he has taken it to a boutique to have it sent to Omega for service. The watchmaker at Omega may look at the condition of the watch and when it was last serviced by them...
"Wow these pivots are in great shape! Hardly any wear on the parts, so I'll report this up the chain that these watches are lasting way longer than expected!" Of course he has no idea that I've serviced it in the interim, and have already replaced all those wear parts at that time.
Here's another situation - watch gets sold, and comes back to Omega for it's first service. No wear in the parts, but the watchmaker reporting his observations at Omega has no idea that for the most parts it has been sitting in a drawer since it was bought, so has had very little use. This is why the "observations" theory is problematic when you get down to the practical side of it.
As for the life testing theory, when I was working as an engineer the company I worked for did all kinds of life testing on new products, and that process often affected my project schedules so I was well aware of what went into it. It was something I was curious about so I did specifically ask about this when I was at Omega for training. They did say that some 8500's were assembled with the silicon balance springs and given to people tow ear for a couple of years, but that was all that they knew of. While it's possible that they do life testing that the people I spoke to were not aware of, all I can say is that based on how poorly the 2500 roll out was done, and how much Omega had to play catch up to solve problem after problem on those, the testing they did wasn't very good.
Omega knows that they will win some and lose some when it comes time to perform a service, and to them that's not terribly important. Looking at the parts that are returned and sheer level of waste in the way they do things tells me they aren't that concerned if another wheel or two that retail for $14 are worn or not. All they need to ensure is that at the end of the day they balance out and they don't lose more than they win on.
I guess for me there's nothing that had been stopping Omega from increasing the service intervals for years, so the fact that this happened at the same time as they moved the warranty to 5 years to keep up with Rolex, tells me this is more about marketing than about the engineering of the movement or the observations of watchmakers at the service center.
I seem to remember Dodge Chrysler increased their power train warranty to 10 years because their reliability was so bad. Gave the consumer some extra confidence.
All makes sense with these details. Many thanks.
If it were me I would have Archer replace all the seals and pressure test. He did everything on my 1997 Seamaster 2531.80 and that watch is perfect. I had him do the 300 meter test after he replaced everything even though all I do is swim in the Bay/Lake/Surf/Fall off water skis etc
