SEAMASTER PLANET OCEAN ULTRA DEEP. Any news???
I guess our watches have a much greater chance of ending up on the ocean floor than in space so in a way these are much more practical, I do go deep see fishing sometimes and I suppose a watch could fall off while casting
Fish weekly and must have casted a million times and never had a watch fall off. 馃槈
Me either, I鈥檓 just thinking the possibility is greater than it ending up on the moon. These are the thoughts that go through my head, probably why I didn鈥檛 get far in life
Did I ever mention how badly I want one of these. I would go into debt to buy one. It's the ultimate diver.
If they make it smaller which they will need to, assuming, the water resistance needs to be outrageous for it to be different from what Omega already sells.
Everyone needs a 1000m
It鈥檚 the only shut up and take my money watch from Omega. We don鈥檛 need another dog-on-watch LE.
Omega seems to just slipped this baby to the news cycle then walked away. Doesn鈥檛 look like there鈥檚 much news on this yet.
Looking forward to seeing new Seamaster 300.
@STANDY @Walrus
With a rubber strap, would that diver float if it somehow slipped your wrist??
edit. Your last photo (just loaded) of diver in bottom of the tank answered above question.
Which leads me to an equally groundbreaking question:
Why don鈥檛 they make a floating rubber strap? Looks like a missed opportunity there.
@STANDY @Walrus
the weight of a watch is considerable, I don鈥檛 think you could get enough displacement with a light enough material with a strap to offset the weight.
Eh, nice design ! That indigo blue goes well with the titanium. Still not a fan of the PO line's double arrow hands, zo.
I own a 2500 PO. About six months ago one of the pins broke on the bracelet, the watch fell into my lap. Good thing I wasn't casting. No idea how it happened, but it makes me a little nervous... and not, the bracelet wasn't on my wrist tightly at all.
That is disconcerting. Do you mean the pin itself snapped into 2 different segments? Were the collars still ok, or did one of those happen to get bent? May I ask if you happen to have a photo of it?
My old 2220.80 is also on a pin & collar system. Before sending it in for service this year (1st service after 9 years of ownership), I had noticed one pin was starting to stick out a little from 1 direction. Had no idea how it happened, other than thinking maybe one of the collars was wearing out over time... thus losing its hold on the pin and allowing that pin to slide outward over time.
What a stroke of luck (or divine intervention 馃憤) that it fell into your lap. I hope to have such good fortunes myself if I ever experience a pin or spring bar failure!
Thanks. It's pretty disconcerting that a bracelet would fail like that. And yes if I remember, I was just sitting at a table having dinner with friends. I won't wear that PO all that often- maybe a dozen times a year, and never in adverse situations. It's never been near the ocean or even any water, sadly. I didn't think to try and find the pin to see if it in fact broke in two or just came out, I was so surprised to find the watch sitting there in my lap. It broke between the first and second link from the clasp, and looking at the holes, they don't appear damaged in any way, nor do they look like ovals. I've been hesitant to go to my AD because of COVID, and I don't want to put it in the mail, so it'll remain a mystery until a watchmaker can see it, and likely even then...
@STANDY @Walrus
When doing recreational diving, it's actually better if the watch just dropped to the bottom as you usually dive in places where the bottom is reachable. Even if you cannot collect it right away it will stay right where you lost it.
When being at certain depths you cannot just go to the surface immediately because that would make your lungs burst so having it float away (and maybe get caught in a current) would decrease the chances of recovering it.
I see your point, but in reality if that Snoopy sunk to the bottom of the lake, say 5 meters, it鈥檚 a gonner for 98% of us. It鈥檚 not so much the depth, it鈥檚 the murky water below 2m. But if that puppy floats for 30secs (or not sinking fast), I might react quick enough to strip off and go in after it.
Amazon a set of pins 1mm longer than your lugs. My 42mm 18k PO is a top heavy fatty. Its a pain to change strap, but it鈥檚 secured.
Beautiful watch!
it sounds like just wear and tear on the alloy of the pipe and pin, possibly smoothed out, if you have a boutique near you with a technician the replacement of those small parts are complimentary.
Like anything on a watch, the bracelet also needs to be maintained. These are checked and replaced at every service, and if you let them go too long, the pin and tube connection wears out and the pin can fall out. Happens more often than people think.
Having said that, I鈥檝e also had many bracelets come in with incorrect parts used. The Omega style pine and tube kissing, and a split pin jammed in, or cases where and oversized pin has been put in with no tubes, and many where two tubes are supposed to be used, and only one is present.
