JonAsh6105
·I'm fairly new to the Omega forums, been lurking a while, though. I'm purchasing my first Omega, the PO 43.5 with 8900 caliber, this Spring as soon as I finish my Master's degree. Until then, I figured I would start building the a Seamaster 166.0324 (like a WatchCo build), since I particularly dig the aesthetics and vintage vibe (my go-to watch is my Seiko 6105-8119 that belonged to my dad). I've reworked/modded a few Seikos, so I figure I have the basic knowledge and skill to put the Seamaster together; if not, I will drop the parts off with my watchmaker and let them take a crack at it.
I have a couple of questions, though:
1) I can't find anything on CousinsUK or OFrei about a movement spacer/ holder for the 565 movement, including a part number or or whether it's metal or plastic/rubber. Any help with this would be appreciated.
2) I understand the "purists" would say use the 565 movement, but what if I wanted to use the 564 or 561 chronometer-grade movements? Do these use the same movement spacer? I see these around for sale in better condition than most 565s...
3) Here's a crazy one: what if I wanted to throw a 2500 coaxial movement into it? I assume it would fit with the correct spacer, but would the stem be the correct length to fit under the crystal? How sweet would that be?
I'm not planning on getting rid of this once I build it, it will be a fun project watch that I could wear on vacation instead of my future PO, hence why I don't care about staying "pure".
Any thoughts / help are much appreciated!
