Rolex Sky-Rocket parts
Looking to find second wheel for a vintage Rolex Sky-rocket movement. I believe the watches were issued to Canadian fighter pilots in WW2.
My watchmaker said the second wheel is broken but otherwise it is running and complete. I have attached pics of the movement and wheel that is broken. I believe it is cal.59 with sub second dial
Any help appreciated
Thanks
Did your repair person tell you it is a SECOND wheel he needs? The second wheel is typically called the centre wheel. If it is the wheel with the seconds hand that is needed, that is the FOURTH wheel! I suspect it is the fourth wheel you need. Confirm that with the repair person. That is likely a Rolex 59, otherwise known as FHF 30. The FHF 30 part might be easier locate.
yes sorry he said its the wheel for the second hand.
Be certain you search for a FOURTH wheel.
I believe it is a two part wheel. The picture of the gear with the hands is the broken wheel but I think its supposed to have another piece (lower gear) attached to it. Sorry I'm not a repair person
You came here for help, yet the information you are giving us is so disorganized and confusing that I doubt anybody can interpret exactly what your needs are. Get the guy to tell you EXACTLY what part is needed, in proper terminology, and maybe then we can help you. If he can’t do that for you, then find a repair person that can.
