Refinished Dial? Omega 157.0001 Gold Plated Model
I spotted that the ll on constellation word has a little ink splatter outside.Is it possible that someone refinished it? Or it just normal things for the vintage watch.thanks you guys🙏
A tiny ink spot by one letter isn’t proof of a redial on its own. Factory pad printing in the 1970s wasn’t perfect, and small blobs or a slightly heavy letter do turn up on original dials. What gives a refinish away is usually several signs together:
printing that looks thick, fuzzy or slightly off-centre, or a font that doesn’t match ther examples of the same reference;
SWISS MADE” missing, crooked or in the wrong spot (yours is there at 6);
a fresh-looking dial surface with wear or marks around the index feet and the dial edge;
once the movement is out, refinisher marks or numbers scratched on the back of the dial.
From this photo the print looks crisp and the applied markers sit cleanly. Nothing jumps out as a redial, but one angled photo can’t settle it.
For reference, Omega’s vintage database lists 157.0001 (1972) as a Constellation chronometer with cal. 712 and a press-in back. If you can post a sharp straight-on macro of the “Constellation” and “OMEGA CHRONOMETER” print, side by side with another 157.0001, it’s much easier to call.
Looks pretty normal to me, these were made in the time period where Omega was starting to cut costs a bit and they were using a lot of different dial suppliers of varying quality, still a very cool ultra-thin and quite visually attractive as a dress watch, I'm sure it'll look great with a suit.
Thanks you for your information.I’m not similar to omega mechanical vintage (usually I go with quartz because of the condition that almost fresh like new) appreciate your answer buddy it’s help me a lot😊🙏
First of all thanks for the detailing on your answer this is the first time I using forum didn’t expect to get the answer very quick and clear like this ,so sorry about the late reply.I’m using iphone to take this picture and this is the clearest one I can get😅 anyway thanks again for your knowledge really appreciate your help.😊
