Well... I am a true newbie.. a budding glutton for all thing that move! So please do show grace if I come off a bit elementary! Constellation 1330 Quartz (Date): Hour hand is not keeping up - Advances about every 4 hours - Mins and Secs run perfectly. I can set the watch with no problems (functions as it should when setting) I just purchased the watch and the stem was not tight in the crown... It appear to also be a little short.... I applied epoxy to the threads and bottomed it into the crown, then backed it out 1 turn (in case it was to short)... Still no joy. The keyless works is holding perfectly also. Looking for some ideas? I am also looking for a 1340-9400 motor for another project! Thanks for any guidance! UPDATE: Well interestingly I decided to pull the crown (as if to set the hours) and leave it out - no the hours are advancing properly... I am very confused now???
UPDATE: Well after further investigation I have discovered the Yoke broke. It appears that the clutch was staying engaged because of lack of spring. See pics
