Postimages hosting and OF issues
Hello OF admins!
As of late, every time I try to link to an image hosted on Postimage (https://postimages.org) it fails.
It shows up on the editing screen but as soon as I hit publish, it gives an error. I thought it could've been because of https but both platforms are using it, so shouldn't be the case.
Tried searching on the forum for similar issues (keywords: posting, postimg), and only saw threads with images hosted on it appearing with no problems...
I know you can upload direct from your computer, but most of the images I have to use are already on there ready to use. So, am I doing something wrong, or is it simply a system incompatibility?
Many thanks in advance,
Lou
Guess I'm the only one with these issues... 馃檨
I've been having issues with Postimage as well here, but I found out that I can select "add photos" then hit insert when it loads in. I'm not sure what occurred that it no longer works.
I suspect no one has answered because the forum owners have been quite clear in the past. Post photos, do not link them. Even if they are already on OF.
Some sites don't like deep linked images in general, I'm not familiar enough with that site to know if they're among them but easiest method is to just upload here really
