Please help. Modern Omega power reserve issue.
I have had my Omega Deville for 5 weeks. It was purchased new from AD. It has 2500D movement.
I wound it 30 winds, set the time. For 4 weeks perfect. It hardly lost or gained time. In the fifth week the watch ran slow each day losing 4 seconds a day.
The watch has been worn 7 days a week for about 12 hours a day. However, I have been stuck at a desk for 8 hours in that day. The rest of the time moving around but not that much. Sometimes sitting at home in evening watch tv.
So this Saturday I did not wear the watch at all. Sunday morning 2am the watch stopped.
Does this sound normal? I suppose I am not active enough?
Should I take it to Omega to be looked at?
I suspect that I am not active enough. I only walk for about 20 mins a day consistently. Journey to train stn and back to train.
I have had my Omega Seville for 5 weeks. It was purchased new from AD. It has 2500D movement.
I wound it 30 winds, set the time. For 4 weeks perfect. It hardly list it gained time or lost it. In the fifth week the watch ran slow each day losing 4 seconds a day.
The watch has been worn 7 days a week for about 12 hours a day. However, I have been stuck at a desk for 8 hours in that day.The rest of the time moving around but not that much. Sometimes sitting at home in evening watch tv.
I know nothing about new watches but if it was a vintage, I’d be taking it back. Good luck
I suspect that you didn’t fully wind it to begin with - 30 winds is not enough - and that your daily movement was not sufficient over time to keep it at this level and increase it.
Before sending it back, try winding it a lot more than 30 times - try at least 60. Then see if this happens again. If it does, then you might have a concern. If it doesn’t, then all is good.
I have read that from time to time it is good to manually wind an automatic watch to give it a boost? Is that necessary?
Do you have a Timegrapher? That would be something I would use to determine if there could be an issue with the movement. Like others have suggested, if you're not very active nor hand-winding to boost the power reserve, then it's very likely it's not ever at full charge.
I always do with my vintage watches. In fact I lost patience with Seiko automatics because you couldn’t wind them.
I will try this shortly
I don't have one. I will give more winds when setting.
Just reset now, movement needed 4 winds just to wake. I kept winding, at wind 69 I heard a faint but firm click at every revolution. This is when I stopped winding, it felt like it was fully wound and the safety slip mechanism kicked it. The first set after purchase I only wound about 25 to 30 winds
There is an issue. I will take to boutique service centre in London as soon as they get back to me.
I wound it from flat 69 turns. In last 10 days keeping great time wearing all day every day. Then I put it on table to test power reserve, it stopped at 22 hours. Oh dear
I may only of got 15% discount at AD but I am glad I got it new and from authorised source.
Booked it into boutique under warranty this morning.
