It is a JLC 481 (first automatic watch to have a power reserve complication). I have serviced it a few weeks ago, but was not satisfied by the delta (40 sec over 6 positions). I had noticed that the vertical positions were faster than the horizontal ones. So the solution seems simple: opening the pins, which actually were almost touching the spiral. And, as it is often the case with the old vintages I usually service, the spiral was not at all centered.
So I opened the pins and tried to correct the position of the spiral. But when I tried to adjust the flatness, the spiral broke just before the stud. Maybe it was my fault, maybe it was already very worn, probably both! Whatever, I fitted again the spiral in the stud (I do not know the English word here - "repitonner" ou "regoupiller" in French). Then I framed a new last coil and adjusted the beat error - which obviously was not good at that point!
Obviously, after this kind of issues and fixing (with my limited skills), I could not expect chronometer performance! But I was not at all happy with the new delta: 90 sec!
At this point, I thought I should do some poising! It really improved the results as I have now again a delta of 40 sec. And I think I can do better by adjusting a pin because I have a pretty big difference between DU and DD. Chris made me understand I did wrong adjusting this pin at its end and not at its begining...
But I was wondering why a JLC balance would be so unpoised - I had to add weight. And I thought I might have disturbed a dynamic poised balance when I accidently shortened the hairspring. Not sure of course. So I thought I could try to understand a little more dynamic poising...
Actually, I am not going to try that now, and certainly not first on a JLC! If I want to get better results with this watch, I will rather check everything you (Al) and Chris have friendly pointed. Maybe I can also do better with my poising. I shall add that I choose not to change the mainspring because it was (like the) original, which has a special device that I thought I would keep.
