dsio
··Ash @ ΩFYou have a 19''' LIB NN 17p from 1922-ish. If you measure it, it should be almost 43 mm wide.
I was just about to say that before you beat me to it...
Okay, 19''' means 19 ligne wide. Ligne is a French measurement used in watchmaking for the diameter of movements. 19 ligne converts to 42.86 mm, so if you can measure the movement diameter only and it's around 43 mm then my ID will be confirmed..... even though I don't know of any Omega calibers with the same shaped bridges so it can't be anything else. The overall case width of 68 mm sounds correct to house a 43 mm caliber.
LIB NN 17p is the model number of the caliber.
