Omega Speedmaster 105.012-66, HF and CB sharing thread!
Look at Nadav's article. https://www.chronoholic.com/post/a-...dmaster-professional-105-012-65-the-moonwatch
looking at your dial, you may have a 105.003-65 dial that was fit on a 105.012-66. they printed the "professional" afterwards (you can see that the texture of the print is slightly different than Omega / Speedmaster)
that remains period correct anyway IMHO, i don't think they were that efficient in terms of stocks/left overs in the 60s.
my 105.003-65 dial is very similar to yours (narrow Ts, slim indexes, same dial colour and texture)
Thank you. Another beautiful watch.
I think you are exactly right. I had noticed the slight difference in print, but had not seen that article before to explain why. I knew that the closed space version was accepted on the CB so I wasn’t worried, but that makes perfect sense.
For me the Ed White has the best dial out of all Speedmasters, but I like the CB case so I am happy with that combination!
Bringing back this thread because I had an interesting observation regarding the A1 24 teeth crown vs. B2 32 teeth crown debate as original to the 105.012-66. Schmitt's Apollo 17 watch from the Smithsonian shows a 32 teeth crown and a few examples in this sharing thread also shows a 32 teeth crown by OF posters.
However, another similarity that these watches have is that they also have "Wide Space T dials" which I assume is a later 105.012 dial (closer to the 145.012 dials), and possible made later 4th quarter 1997. This could provide some proof that the 32 teeth crowns were used during this transition.
My 105.012 HF with Wide Space T dial, Oct 1997 production, B2 32 teeth crown.
1967 you meant... not 1997.... mine is from 09.1967, possibly same batch with very dark (almost glossy) dial and pumpkink indexes ?
Thank you. It is a really nice dial, in fact it is hard to believe that it is almost 60 years old!
Yours is beautiful as well. I don’t suppose you would mind sharing some detail pictures of your lugs from different angles? They look super crisp. Or anyone else who has a CB with excellent lugs!
I think mine is going to possibly need some laser welding on the lug holes/lugs in the future so I am pondering whether to also risk getting the bevel line sharpened. One lug in particular has lost a lot of definition.
I hope it helps
I hope it helps
That is great thank you. A few questions if you don’t mind to check that I have interpreted them correctly!
The flat portion of the lug has a gentle slope towards the bevel? Or is it horizontal/in plane with the dial before the bevel line?
The bevel lines themselves are at similar locations on the lugs or does that vary?
And how much material is there between the lug hole and the end of the lug? This is my main clue that mine has been polished as there seems to be too little material on the bottom left lug in particular and the bevel is obviously too soft.
Mine for comparison:
I am hopeful it is possible to improve the lugs as they do still have the CB shape even if material has been removed.
i'll remove the bracelet and look at the lug holes, but to be honest, i would not touch yours...
on the back on the case, you should have those flat bits as shown below. it should be flat and sharp
Don’t worry if it is too much trouble! Really appreciate the help already.
It has the flats, but they are a bit uneven in size.
i think that i did not show you mine, after a lot of work for its overhaul
realizing the 1039 was never removed from the watch.... and i can't remove the spring bars so easily, so i'll leave it as it is....
That brings a risk, that it will get stuck permenately ( spring rusted or blocked ) and leave the end piece in the hole when trying to break it out. Which means drilling it out.
So give it a mild soak in light oil or lock spray, start wiggling and moving it so get them out. New bars only costs pennies
Please don’t take any risks with it on my behalf! It is too beautiful a watch to risk scratching.
Thanks again for the help.
t
thing is, spring bars don't seem to have the notch on which you can press with the tool to remove it....
t
Bummer, no shoulders on the bar to grip on to ?
That leaves ; to a watchmaker with strong tweezers and good skills, or have him cut/drill through the exposed bar section. But it will help if you start soaking it a little.
@Frederic_gva You were absolutely correct about the dial. Mine has all the characteristics of a B2 MK1 dial (a 105.003 dial with Professional printed later) outlined in the article. Someone had too many coffees before printing mine though!
That dial is beautiful, amazing condition
