Hi all,
Just taken the plunge and would appreciate people’s thoughts on this one to double check my notes.
125.012-65, serial number 24011xxx
Dial and Hand Lume seem correct for the dial markers, but hands are a very different color. They both exhibit exactly the same amount of brightness after exposure, but are then both totally inert after 10 minutes in the darkness. Presumably they are tritium?
Stepped dial correct finish with the larger hour markers running right to the edge
Pushers - 5mm x 2.7 (or 3 mm, having trouble to get a good measurement) I think they look like the correct type, but i don’t have a good eye for this bit.
Bezel - good overall condition, slight dent on left hand side, but not really visible.
Omega name and logo on the dial, correct font and spacing
Case condition - edges seem fairly sharp with brushed sides. - seems good with minimal marking
The T Swiss T script is nice and close to the scale, correct for age
Case back, correct double bevel, looks better than the photo
Query’s
Crown, seems to be a 1970’s service replacement.
Crystal logo - can’t make up my mind, but think it’s the early narrow symbol type?
Movement - generally clean, some very small scuff marks from service around a couple of the screw heads etc. but nothing nasty. I guess needs a service as losing around 17 seconds in 12 hours undisturbed lying face down, and the chrono second hand occasionally seems a little jittery when its running.
Anything I’ve missed?
Thanks all
