Omega snoopy 50th problem
I'm surprised a boutique would do this, but well played. Let's hope it was a one off problem.
The one in Zurich will, they have Omega watchmakers there and it's awesome to talk to them about all the old & new tech, positives & negatives, show you stuff, etc. We've talked to the same one a few times now and he's super open and forthcoming.
Not so much in Nashville, USA.
We all definitely feel for you and a mistake was definitely made, but this is an allocated, limited edition watch that Omega is not likelygoing to be able to simply exchange on demand for you. For the record, they do sometimes do that with their normal production run stuff.
I totally understand the disappointment. No idea if this helps but at least with a warranty claim you are getting your watch back, the one that YOU waited for.
Maybe try asking Omega to expedite the service, or throw in a 3861 bracelet (or a discount)? There's no guarantee that they will do either thing but these watches look fantastic on the 3861 bracelet and it's always nice to have options. Just a couple of thoughts that you might try.
And, Merry Christmas!
I had an issue with the crown on my Heritage 300 only a week or so after I purchased it from my OB. They replaced it immediately with their current stock. Bummer that you are having an issue with a not-so-easily replaced model. Good luck!
Hello
I'm new here
I bought two weeks ago a snoopy 50th new.
Tonight I showed my friends the back case, when I used the chronometer after the reset snoopy didn't come back behind the moon but remain visible. Now every time I use the chronometer after the reset snoopy continues to advance in his lap but does not return behind the moon
Someone could help me.
Thanks a lot
So glad to hear this worked out for you; I’m picking up my Snoopy on Saturday and will keep your experience in the back of my mind when I check her out
One problem was solved, but the other you refer stopping the watch while you activate chrono may still be there (hopefully not). Good luck.
Also chrono problem is solved.
