- Posts
- 4
- Likes
- 1
Sorry for the delay. I don’t have the proper tool, but just with a ruler it looks like my caseback is 32mm diameter. The photos I have above are the only ones of the inside, so I can’t answer the question about seal. All I can say is that the caseback snaps on just fine. I’m afraid I am on the “enthusiast” side rather than the technical one!
Good luck anyway.
This case uses a red gasket with the correct inside diameter to fit the flange on the case back, and the correct outside diameter to snugly fit the inside diameter of the case. The red gasket is fitted onto the case back first, then the case back and gasket pressed onto the case. The red gasket performs a double function. It seals the case, but also holds the case back on. And yes, the gasket is thick.
Great, I was hoping that would be the case. It’s easier than finding another case back!
I don’t suppose you know the best place to get one from do you? Before I start trawling the internet
Thanks
