Omega Seamaster 166.010 advice requested
Hi everyone, thanks for all the support and advice. Great to see the engagement of this community. The bracelet size shouldn't be too big of a problem for me, but good to note. Also thanks for pointing out the proof of service, which I will ask about. Interesting to read the debate regarding the originality of the crowns, they seem to differ quite a bit.
I think the case has been refinished.
Art
Curious to hear why you think the case has been refinished? Does a case refinish include the dial?
I don't recall this reference having vertical brushing. The dial is fine.
The 166.010 and 168.024 most definitely have vertical brushed sides 😀
Indeed they do... and I did have my case refinished (bracelet too) to correct someone else's crappy attempt, which left the watch looking a whole lot better. My watchmaker is highly trained and talented besides; he knows how far to go, in that yes, there were some flaws left, because trying to remove them would have caused issues.
Sometimes I'll ask about something, and the answer turns out to be "no". That's one of the things you pay for.
Vertical brushing is correct.
I owned a 166.010 briefly 10+ years ago which had vertical brushing.
Wasn't sure about the correctness of vertical brushing at the time, but apparently the conclusion I reached then was wrong.
Art
Correct crown for this reference (no date version 165010).
I’m getting absorbed in finding a correct thin scalloped donor crown for my 166.010 and 168.024 Seamasters, both of which have thicker crowns. The examples in Tamura-san’s photos look to me like two different crowns.
I’m also really wondering how it is that so many 166.010/168.024 watches sport the thicker crowns if this isn’t the way they left the factory. If the thicker crown is not correct, why would so many have had to be replaced? Was there a high failure rate for the original thin scalloped crown? As I mentioned before, even watches that have seemingly never seen service have the thicker crown.
First, the thin crown was discontinued.
Also, changing crystal and crown at every service has been traditional for a long time.
So, perhaps it was discontinued because it was not sufficiently waterproof. We'll never know.
Same crowns😀
Just to follow up on this, my watchmaker in Tokyo agreed with @SkunkPrince’s observation. He said Omega routinely changed the crown during service and independent watchmakers with Omega accounts followed suit. The original scalloped crown was discontinued and the thicker crowns were seen as an improvement, so at least in Japan, any properly cared-for 166.010/168.024 likely had the original crown replaced during service, whether anything was wrong with it or not. This explains why 166.010 models with the original crown are so scarce/
All brands do this. The reason they change it “whether anything was wrong with it or not” is because when you service a watch, you know it’s not going to be serviced again in years...probably at least 5 years. So even if the crown is good now, you don’t know when it was last replaced, and how long from now it might be good for.
Also, no one is going to provide a warranty without knowing that the seals are in good condition.
I understand this is not the current collector sentiment, but these were just watches when they were bought, not collector’s objects of obsession.
