omega seamaster 120M
Unless a seller had a recent service receipt from Omega or some reputable shop like Archer, I 'd ignore any claims about service, especially with a 20 year old watch. That's one of the best things I learned from the more experienced folks here. My seller had a BIN price of $1300, and I offered him $700, knowing I was going to send it for service, regardless of how it looked or ran. Turned out, it badly n
is the calibre 1120 that expensive to service?! 馃槻
Depends on what you want. For a swish & lube job at a local jeweler, probably not. I needed a lot more than that, plus I like the 2 year warranty.
Watches of this era are some of the cheapest Omegas to service with the lowest overal running costs since they use the ETA derived movements particularly the quartz which can take a lot of abuse and still run fine. I wouldn't let servicing put you off. All mech watches will typically need attention every 5-7 years but quartz can be left longer (a cheaper battery service can be done when the cell expires instead), Water proofing needs to be checked/remedied on both periodically if you intend to get them wet. You may choose to spend $500-600 on a full service from Omega themselves but it is by no means your only option and competent servicing is out there at as little as $150-250 depending on the issue or what is desired.
the only watch I truly worry about for service time is probably the speedy reduced. The rolexes $400-600, but the speedy reduced ive heard awful things!
I service the odd 1120 based watch now and then...馃槈
The 1120 isn't any more expensive to service than any other automatic movement with date. I personally charge the same labour for this movement as I would for a Rolex 3135, or a vintage Omega 565, or a watch with an ETA 2824-2. What has the potential to make it a more expensive service is if parts are needed, and specifically what parts those are. Having said that, the parts for this movement are pretty inexpensive overall, when compared to say a vintage caliber like the Omega 565.
I gave this example in another thread recently - reversing wheel for al 1120 on the left and one for a 55X/56X series on the right. Left is $14 and the right is $104.
Although any competent watchmaker can service an 1120, contrary to popular belief the 1120 is not just an ETA 2892A2 with different decoration. Many parts are not interchangeable between the 2892 and 1120, for example the bearing for the rotor is completely different. This is an 1120 bearing mounted in a fixture for assembly to the rotor:
This is a 2892 bearing:
I replace the bearing in probably 50% of the 1120's I service, so this is a common part that is needed, so access to parts is a consideration, even if abilities of the watchmaker are not.
nice so far the aqua terra is nice, but id hate to beat it up in the hospital, suddenly im reconsidering that 120M!
