Tom Dick
·evening all
Just wanted to show off this little beauty, it's something quite special simply because it's omegas first ever prototype of a megaquartz 32khz (omegas first in house Quartz movement)
The watch dates to 1970, it is one of a series of 14 prototypes made to test the case design and movement design of the megaquartz 32khz movement
The eagle eyed will spot that the case is remarkably similar to the f300, although larger and with the integrated pushed for adjusting seconds and date! The movement is a complete prototype unit and the dial is branded electeoquartz not megaquartz
The movement is hand engraved and the case back stamped 1310 serie 0, which was the first test run prior to any public testing or display of the MQ range
It's keeping second accurate time and frankly I am thrilled, will update more later but wanted to show her off, need to change the battery for the right one but thankfully have cleaned off the black seal gunk (bless you baking soda wipes) she's a very very special watch
Thanks Tom
Thanks Tom
