As i don't have enough privileges to post in WTB, i am looking for a titanium clasp to fit a polaris all titanium bracelet, i have a NOS stainless steel 1455/462 clasp that i am willing to swap with a cash difference or sell separately. Can anyone help.
I'm sure you're just trying to make a watch right, as many of us do, but there is a reason that there's a minimum post count required before you can post a WTB. you're skirting the rules of the forums. but cat's out of the bag now. good luck.
My Polaris has a titanium bracelet (pretty certain about this) yet the clasp is SS. This makes me think some were sold this way.
sorry Oddboy for being cheeky , hope nobody worries too much, i'm trying to add to my posts so i get the privilege. Deafboy, you could be right , this is my fourth polaris style and I do like the double deployant clasp, my st st clasp just doesn't look or sit correctly. I've also noticed that most of the titanium and Ti/Au models from Germany have the double deployant clasp
I think you must be referring to the "butterfly" style clasp like I have on mine (slightly helpful pic attached from the web). Unfortunately, it's away at the spa currently so I can't even tell you what (if any) references are on it. In any case, unless you have the same model as me (a TR 378.0885) I wouldn't guarantee it would fit your bracelet as I don't know whether the sizes of Polaris bracelet links are uniform across different models and clasps are interchangeable. Maybe @Archer will wander past and let you know whether these clasps are still available. Good luck with the search. *edit* Better clasp picture found
Thank MAL , thats exactly what i am looking for , ref 1475/462 , also 1485/828, and the tubes at the end need to be 8.5 mm long If anyone can help or give approx cost if available?
Also you should consider whether changing the clasp will change the effective length of the bracelet when closed. You may need to add or remove full/half links.
I have compared a Ti double deployant clasp with the st/st slide-fold clasp and they are very similar in the amount of length they take up.
Clasp for 1475/462 is part number 117TB1475462. Nearly $400... Clasp for 1485/828 is part number 117TB1485828. Nearly $400...
