Just bought a PO liquidmetal. Looks great, but the crown does not pop out. The lume is correct, the balance wheel is black as it should be, also the helium escape valve points correctly and the lug has a serial number, matches the number on the movement as well, When I looked at replicas on the internet, one that I found look the same except the balance wheel. Any input is appreciated.\ thanks
Your watch is fine, the link you posted was automatically removed due to us not allowing links to replica watch sites but yours is fine
If the crown is a bit stiff it could just be the seals either being stiff or a bit gummed up, my dad's Aqua Terra 8500 got that way eventually.
So do you like it? What are your thoughts. I got one several weeks ago and love it. Quickly became a favorite.
Ti 8500 is probably my second fav watch after AT 8500. The Ti and Liquidmetal make the watch amazing to wear casually! Only took those two watches on my wedding/honeymoon as you don't really need more than either one no matter where you find yourself. Sent from my iPhone using Tapatalk
