Omega noice bezel seamaster ceramic... issues?
Hello to all members! I am here and I want to resolve one problem from my best friends omega...
The video it's from YouTube but this issue make to my friends watch...
So it's need service the all system bezel?
Because I read from many members this problem...or it's the omega bezel that make this common please?
I need the opinions from expert members please ..the watch has one year more warranty..it's easy fix?
Really all the best!
Take it back to a service centre. Shouldn’t be that loose.
Those bezels have a little bit of play, but from your video it does appear excessive. This isn’t something you can fix by yourself, unfortunately, unless you want to potentially damage the watch and the bezel.
If you have an Omega boutique nearby with a watchmaker (or even a tech with the proper training), they can fix it in a few minutes. Otherwise, you’ll need to send it to a service center to have it fixed under warranty, and that will take several weeks to months.
I have that exact model Seamaster and do not have that excessive level of play. Perhaps it just needs a new bezel spring? Should be an easy fix for a OB.
This is serious problem? The watch its little use ..what is this? Why Omega ??
When I owned one of these, I had this problem. I think Al said it was the click spring. It probably lost a tab or two. It’s a pretty quick fix from my understanding, but since it’s under warranty, just send it in
Most bezels will bump like that, I mean the bezels which do use a polygonal steel spring.
Each and every pro watchmaker will be able to replace this spring, just make sure your watchmaker can order Omega spring.
If this is under warranty I would have sent it for Omega warranty service.
So you believe it's the click spring? You my last video? The bezel if you see carefully open in many places....
You think its open because it's not good the click spring?
Thanks a lot!
I bet it is bezel retaining spring, this is what "locks" the bezel horizontaly and vertically.
Left is click spring, right is retaining spring.
Now I see....I am sure it's from click spring...but it's issue from factory ...why? I read many same issues from this seamaster ceramic ..
My omega seamaster ceramic old version pass today the door of omega service...
Let see what they will say ..it's problem from spring bezel click? .....
Yes...just I am little disappointed...why this happen this think from omega?
This is literally the reason for a warranty.. when little things like this happen rarely they get fixed.
