this example on ebay has a normal, thin replacement dial without the antimagnetic properties of the original , thick soft iron dial with the cut out luminous wells. easy to spot at the 8 0`clock marker. the lume is painted on top of a white printed dot. as all the others are. kind regards. achim......... https://www.ebay.com.au/itm/Militar...m=162909732358&_trksid=p2047675.c100011.m1850Purchases made through these links may earn this site a commission from the eBay Partner Network
The movement looks like it was beaten with a stick...I personally would avoid, esp at the posted price
