Omega f300Hz serviced
Pictures please!!! 😗
Here are few Pictures, in order,
M3 (1963) 214 (this one is almost perfectly brand new)
M8(1968) 214 Railroad Approved
M7(1967) 214 Railroad Approved
N7(1977) 218 UFO case
N4(1974) 218 Tobacco burst dial
M3(1963) 214 W/Chapter ring
N0(1970) 2185 Astronaut Mark II (I love the patina on the dial)
and I will post a few more more in the next few days as I take more pictures;
here’s mine
that is one gorgeous watch! Looks like it just came out of the box! I will try to post the last few pictures in the next couple of days.
Every time I wear this one, I want to listen to Fleetwood Mac and watch Sleeper.
That is nice. Really like that case. Sleeper too!
Not sure about the Fleetwood Mac component but each to their own.
Yep! totally seventies beautiful watch!
So I finally got a chance to take some pictures of some my other "Hummers". First one my SS Spaceview with NOS hands and lens replacement. It has been a little bit of a mystery. First year of Accutron 214 movement production was 1960. For those who don't know, the date of the manufacturing on vintage Accutrons is on the back case indicated by a letter and a number with "M" for 1960's and "N" for 1970's.For example M7 being 1967. I have never seen one without it but the back case on my Spaceview has no date indication! My guess is this was one of the very early 214s and hence the no date stamp, but that's just a guess. The second one is my latest Bulova purchase a 1973 Asymmetrical GMT Mark IV Astronaut. This watch is pristine and as close to new as it can get. It also came with the original band and buckle in relatively good condition for a 50 year leather strap. It seems like it was sitting in a drawer all that time. Very happy with this find.
Sometimes they`re on the inside of the back.
Yes I have seen that as well, but nothing on the inside either!
[...]I have never seen one without it but the back case on my Spaceview has no date indication! My guess is this was one of the very early 214s and hence the no date stamp, but that's just a guess. [...]
This is not an early 214 case. These do have a different setting knob:
My guess is that the number is worn off.
Good to know, Interesting! Although I thought of worn-out number as well, so I looked at where it should have been placed with all kinds of magnifiers but there is absolutely no trace and the rest of the number stamps on the back are pretty clear and bold and also there is a miniature date stamp on the front between the tuning forks in many cases that is missing as well.
Maybe this is a spare back which ist changed at a service at Bulova some have problems with the "stem".
Could be. If it was, they fixed it. I currently have a stem problem with one. Even my watchmaker is having trouble fixing it. Tried replacing 3 different stems and backs and it still pops out or won't set. Thinking about scraping the whole thing and find an entirely new case.
Hi,
Very interesting post. I am new to the forum and I inherited a f300 seamaster a couple of days ago. It is in an ok shape but I’d like to get it serviced in the Netherlands.
Would you have the contact of the Dutch Watchmaker you’ve used to service yours?
Thanks,
Dear All,
This Omega f 300Hz I bought recently was in need of a service, she was running 15sec/day ahead (too much for an accutron !)
Here the watch :
My watchmaker did his best but was not able to get the watch back to original specs. One need a very specific equipement to work on these Accutron movements, such as high resolution binoculars or special timegrapher, and ofcourse the experience.
A bit of research here and there disclosed the following possibilities :
-French specialist “cliquet75”
-UK, Electric-watches
-Rob Berkavicious (Bangkok)
-Dutch watchmaker
Regarding costs, they all are about at the same levels .. depending on the parts that could be required.
I inquired with our belgian customs administration on how to send a watch abroad for repair and not have to pay duties upon return. This turned out to be a nightmare .. I was advised to secure some customs documents that are available only in transportation companies .. only one such company answered they could provide me with the documents but for a fee of minimum 200.€ .. I gave up !
Left to me were the french and the dutch watchmakers.
I choose the dutch watchmaker and I got the watch back last week.
The works performed were excellent, I received some pics during the process .. here they are with the comments of the watchmaker, I believe they could possibly be interest for fellow members having the same problem of servicing an Accutron movement.
The Index Finger with the Juwel which is driving the Index Wheel was out of alignment and the movement was dirty and not running.
The watch has been inspected and the Electronic Block with the gear train has been disassembled clean oiled reassembled and Adjusted. The Index Wheel has been replaced to make sure that the movement will run for another 20+ Years.
Here is the Index Wheel with the mikro Dimensions. Notice the corrosion made around the teeth over the years.
There are signs of cell acid damages on the Cell Minus Pole collector resulting poor electrical kontakt. This issue has been solved by coating the Cell Minus Pole collector with electrical silver coat. See damage in the picture.
The O-Ring in the watch case has been dissolved and has to be removed and replaced with an original O-Ring. The attempt to seal the case by inserting an O-Ring in the Case back was not good idea. This issue has been solved by cleaning the case from the old dissolved O-Ring and inserting a new original one.
Today the watch is running in Chronometer range the way should be, but you mentioned the date stop working. As mentioned earlier this is one of the typical failures the F300 movement has since the Date disc is made of 50+ Years old plastic.
I will work on the dial side and I will replace the old damaged disc with an aftermarket Metal disc which will run forever and I will give you full 2 Year warranty for all watch functionality
I have proceeded with the revision of the Dial Calendar part and here are the 1st impressions.
Here is the damage tooth under 250 times digital magnification. It is just minor but enough to stop the disc from jump at 24:00 cause the calendar gears just hitting at 24.00 ONLY the top edge of the date disc teeth.Quick date set is not affected at all as the calendar gears use the whole teeth to move the disc to the next date.
Here you can see the original plastic date disc versus aftermarket custom metal version.
I will need to test the watch for a week before the delivery to make sure everything is the way should be and verify the accuracy on analyser and on move dynamically.
From the final test on Tuning Fork analyser you can see that the Omega is running on 0 Sek/day.
A nice result, as you can see !
Thank you for your attention,
I would like to recommend this watchmaker in England: https://electric-watches.co.uk/
Paul restored a beat-up Eterna Sonic that wasn’t working for me and did a beautiful job at a reasonable cost. This watch has the same ESA 9162 movement as the Omega Deville electronic I own.
Before
After:
Another recent purchase which is being overhauled by Paul @electric-watches. Very well preserved.
Hallo Friends,
I am an Omega Constellation fan, so as well a hummer F300Hz was on my list.
I started with a gold plated Version ref 198.001 see below.
Wether I should own an 18k version in my ever lasting collection, I am uncertain. Todays 50 year old 18k watches should last forever. The mechanicals will, as they are not worn often, only the oil may get dry.
What are my concerns?
- I do not know, how it will run in 30 years with my grandchildren.
- Should I keep it running in the drawer for years?
- Or should I take out the battery and will it start running in 5 or 10 years?
- How is the Omega service today and then?
Any advice is welcome!
Greetings Konrad
Btw. My watchmaker says Murata cells are the best regarding no leaks, since Sony doesn't produce these any more.
