Omega Electronic F300Hz Geneve Chronometer 198.030
This Omega f300 Tuning Fork "Hummer" Geneve Chronometer that was fully Serviced in February 2023 and carries the balance of the 24 month warranty from John at Budget Accutron. (service cost was around 420)
The watch has been full disassembled, cleaned, new gaskets, coils, OEM dial feet, battery holder, oiled, reassembled and is running like new!
The case is in good shape and the case is sharp with sunburst brushing still visible, it has likely never been polished. some minor marks, but no deep gouges.
The radial pattern on the dial gives it some nice depth.
The acrylic crystal is clean with minute signs of general wear.
The time and dates set as they should and the watch keeps good time and is Humming away nicely.
(The Omega f300 chronometers were tested to mechanical movement standards and passed with flying colors. These watches differed from your run-of-the-mill quartz watches - the tuning fork means that the second's hand sweeps in a smooth continuous arc around the dial and it emits an audible hum as it powers the watch, hence its nickname.)
Movement Type: Tuning Fork
Caliber: 1250 is based on the ESA 9162
Jewels: 12
Width (without crown): 38mm without crown
Lug width: 19mm
Lug height: (lug to lug)42mm
Thickness: 11mm
Comes on an a nice leather single stitch strap with steel buckle.
Please see photos ands they are a vital part of the description. (PM for more if you want, In trying to utilize a 100mm macro lens, they came out artsy)
These are getting hard to find, and even harder fully serviced.
$700 Net Shipped within the US. Price DROP to $600
Trades possible. I have 2 F300's for sale.
Thanks for looking. I have many years of positive transactions and feedback on the WUS forum under same user name, feel free to message with any questions.
(here is an excerpt from John about tuning fork watches: "the remarkable tuning fork index mechanism of the Accutron works well only when it is properly phased and adjusted. The jeweled index fingers must have the proper force pushing against the index wheel and they must have the proper orientation with the index wheel and each other. If not, poor time keeping, stopping, or rapid time gaining will result. There are 9 separate and precise adjustments required for the index mechanism alone. Once the index mechanism is fixed, fine adjustments in time keeping can also be made by adjusting fork frequency." )
