Having problems with a Omega dynamic 166.039 where the previous watchmaker has put a normal stem in instead of the split one? I thought i could remove the crown with the other part of the stem? As i thought the stem was a split one i used a presto tool to pull with. Nope i broke the stem of instead? Right up next to the crown? Now i can't get the movement out as the stem is in the way? Movement is a 565. What to do?
Yes. Demand it be changed. One of my watchmakers did that. AND HE DIDN'T TELL ME. Guess what I did. Yes, I ripped that son of a bitch out when I went to check the serial number on my movement. He ended up fixing that at his expense.
