hallo to all got this watch from my grandfather , can you halp me with details on the watch , year of manufacture and so.. the front dial do not look like any other that i see on the pics that i found in the net , i would appreciate any halp , thank you , Yoav
It is a case reference 168.004 (see the engraving on the inside of the case). The movement, case and crown all look original. The dial, unfortunately, is another story. It was poorly refinished many years ago. Watch is from the 1960's. Hope this helps, gatorcpa
The hand set seems to have been changed along with the dial refinish also. They should be long to the edge for the dome dial. To restore the original look of the dial, the hand set needs to be changed too.
Is there a data base that by the serial number of the watch i can see the configuration that it was released to market ? Thank you Yoav
http://www.omegawatches.com/planet-omega/heritage/vintage-watches-database When you input yor reference number put it in this way... 168.0004
