Omega Bracelet ID Help? (Whooops!)
Hi OF,
Or should the title be: Learning to Fish; what the heck did I catch?!?
Well I obviously pulled the trigger too quickly with bad pictures and now need a bit of help to ID.
I bought what I thought was going to be an 1175 with 47 endlinks by the fuzzy pictures and measurements given. What I ended up with is a bracelet with the exact same dimensions as an 1175 but with the rounded links of an 1171 or 1125. But clasp and link dimensions match neither and are exact to the 1175. Clasp is 30x17mm, widest link is 18.5mm, and last link to connect end links to is 10mm. Links are connected with springbars, not pins or screws. The endlinks that I thought were #47 are #77. Knew it was a gamble and some you win, some you loose. I didnt win this round but its probably useful for something if properly identified so thanks in advance for your help.
Pictures, 1175 on left unknown on right. Clasp picture is the unknown bracelet.
1175 is towards back of the below picture
huh, that's interesting. I just bought a 1125 and it looks just like your unknown bracelet. Maybe it's an early unmarked example? I hadn't realized the 1125 is so similar to the 1175.
Edit: To clarify, I'm actually in the same/similar boat as you. I bought my 1125 with a snipe bid right as an auction was ending and I thought it was 1175.
1125 should have a 9mm last link and this has a 10mm, 1125 should have a widest link of 18.8 vs 18.5 on 1175 so subtle differences but this matches up size-wise to 1175 .... Heck if it just had the 9mm end piece I would add a set of 560's make it an 1125 and call it a day but now I want to know more. 馃嵖
Hmmm, so take this with a grain of salt because it seems like my calipers are broken. I have a gold plated flatlink that I think is technically a 1175/48 and the end piece is definitely larger. Mine seems to measure a little over 10mm. However, the end piece on my 1125 seems to be more like 9.5mm.
I'm also really curious how. Hopefully I can find another caliper and get some exact measurements.
