Omega 564 spacer ring screws
Hi,
i am fitting a 564 cal into a 168.050 case. It requires a spacer ring which I have. There are 2 screw holes on either side near the dial feet screws. These line up with 2 holes in the spacer ring. I am trying to find out what Omega parts they are.
thanks
Hi,
tried finding these for sale but having no luck.
So you gave up after searching for less than an hour?
Not really. The reference shows no results on google. I assume it is the same reference in the Omega 565 parts list (2211) but the image and ones found on eBay do not look right.
the hole is not recessed to loose the head. Looks like it should be a standard grub screw. The 2211 looks similar to the dial feet screw.
Well, good luck then.
