I love the look of these, but they are older than my usual purchases. How do they wear and how reliable are they? Lastly how does this one on eBay look? http://www.ebay.co.uk/itm/121411443933?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649Purchases made through these links may earn this site a commission from the eBay Partner Network
That one looks pretty good at first glance. Odd that they are showing only a copy of the extract and they hid the serial and case numbers. That's a warning sign. If the service was performed correctly, it should be just as good as any cal. 321 Speedmaster. The movement is more or less the same. Hope this helps, gatorcpa
I respectfully must disagree the movement is quite different compared to the 321 movement - what they do have in common is that both are Lemania movements and very reliable... 321 is much smaller and has an hour recorder, 33.3 has not and is large at 33.3 mm
