Hi there i need your help - please tell me what do you think on it? It will be 30T2? thanks & regards
No. probably a cal. 26,5 or similar. Watch should be maybe 30mm in diameter. Pictures are not clear, but looks like a older redial to me. gatorcpa
IMO it could be well a 30 SC T2, early cases look this way... if it measures about 34-35mm there is most probably a 30mm movement inside. To give you information about the authenticity of the dial a much larger pictures would be needed.
No, ref 2179 has a different case back! As it is a 35mm case it is an early version of 30mm, maybe a 30 Sc T1
This picture is still far too small! Try to provide an XXL image with high resolution and we may be able to help you...
Hello, Interesting, The caseback is typicaly one you would find on 23.4SC/25.5 Naiads from the early 40's (date confirmed by the serial number 10.170...). Can't be a 26.5 as it has a central second, so I would have said 23.4SC. However 35mm is more a 30SC like diameter than a 23.4, so I definitely need a picture of the Inside to know.
What serial no is on the movement? Also, what does it say inside the caseback? Reference? Also there is a 3-digit code there. Is it the same as stamped underneath one of the lugs? The movement designation is under the balance, what does it say?
