Posts 170 Likes 34 konung39 ·Oct 29, 2024 JimInOz The tube is pressed into the body on cases of this vintage, later many models had screwed in tubes. A competent watchmaker can rectify this issue. Pressing the tube into the watch case yourself was a little difficult, but quite doable.
Posts 282 Likes 64 SerP ·Oct 29, 2024 konung39 Pressing the tube into the watch case yourself was a little difficult, but quite doable. This would be easier to do by preheating the housing in hot water (boiling water from a kettle) and cooling the tube in the freezer. 😉
Posts 170 Likes 34 konung39 ·Nov 2, 2024 SerP This would be easier to do by preheating the housing in hot water (boiling water from a kettle) and cooling the tube in the freezer. 😉 Thanks for the advice! Luckily, I didn't need it, and I even got by without a press.
Posts 282 Likes 64 SerP ·Nov 3, 2024 konung39 Thanks for the advice! Luckily, I didn't need it, and I even got by without a press. Ok. 😀 Such "trick" can be useful if you don't have an equipment and you need mont parts with light-press fit (for instance tube to water tight case). Works good.
