hello, i recently buy an omega from ebay at usd320 as attached photos. however, that watch is not running well and the back cover is loose. if you look at the movement, you will see a strange screw sticks on the movement and the rose gold color of its movement is badly worn and i think the dial is repainted. could anybody here give some suggestion what should i do to this watch or i should return this watch to the seller.. thank you
You've answered your own question. Overpolished, redialed, with a poorly working movement? For what possible reason would you keep it? Return it and sin no more.
