Hi everyone, I wondered if anyone can help me with this watch. Heres what I think I know so far - Omega 2325/7 30T2 1940s Probably later hands Looks Like an original dial Movement looks good I have only seen one other watch online with this model number and it doesn't look the same - https://forums.watchuseek.com/f20/my...ga-454122.html I have my heart set on buying a Seamaster 600 so will probably sell this on, and information on this watch would be amazing and also a valuation. Thanks, Etienne
Dial redone, maybe years ago and hands not correct -gold plated and metal case, no- Crown maybe an original Omega but I think better would be a "mushroom" one.
Thanks Germanicus and x350 xJR, I realise I cant sell on this forum because I am not an experienced member. Do either of you or anyone else have any advice on the value of this watch or know where I could find out that information. Thanks, Etienne
I’m confused Etienne. You say you’ve only seen one other model online. Have you tried googling ‘omega ref 2325’ ??? There are quite a few. You’d see that your example is not very consistent with what is out there. You want an evaluation of the value of the watch, it’s worth about $75 for the case and $75 for the movement. Good luck.
Hi Rman, I am new to watches so I don't know how the model numbers work, so yeah I have seen lots of 2325 watches but what does the /7 mean? I have only found one other 2325/7. Thanks for your evaluation. E
That means it’s the 7th version of the model. All the information you need is here on the forum if you are interested and search. If you are interested in a Seamaster 600 you can educate yourself beforehand so you don’t make the same mistake twice. Cheers R
