You are right, the early 1000m were fitted with a 600m dial and if they are original they are rare.
The 1002 Movement with a 315..... serial also dates it to the early 70ties, later 166.093´s used the 1012 movement.
So yours could be one of the rarer early versions, but even if you order an extract of records you will never know if the dial
was originally delivered with this watch.But i would bet it was.
On the other hand i have to say that the case really has been badly refinished. The edges are pretty soft now and it should have a radial finish
instead of the amateur Sunburst finish it has now.
What about the Crown, was it unscrewed when the Pictures were taken, because it protrudes way to much from the crown guards.
Else i would have it serviced but leave dial, hands as they are.
Very very nice find
