Durability has never been a concern for me and I'd be equally as annoyed with a dented aluminum bezel as a shattered ceramic. I'd still be replacing it either way, so it's kind of a moot point to me.
I don't think there are better practical options than ceramic for bezels. Synthetic lab grown sapphire is close, but is equally likely to crack with shock forces as ceramic and costs a small fortune for thick large pieces.
Despite wrecking the stainless steel bezel, I personally have never damaged an aluminum bezel insert, but I know it can and does happen. I only have a few ceramic inserts, most of my watches have steel inserts, actually, and I wouldn't use those ceramic component watches like I did the aluminum ones in the day. The best practical material is just not ceramic (or sapphire). It is a fine material, can make a watch look great, but it's a real liability.
I was worried about scuffing the aluminium insert on my SMP when I got it, but I've had it coming up on eight years now and it still doesn't have any more than the faintest of scratches on it. They're not that precious, thankfully.
If I'm honest though, if I was gonna buy a newer reference, I think I would prefer ceramic. Chances are, any damage that will break a ceramic bezel will dent/gouge aluminium so badly you'd be replacing it regardless, I agree with Dirk063 on that.
Yeah, you're likely correct for the SMP. I can only speak of my experience and one very, very different watch, the GSAR. The GSAR has a very prominent bezel and while I damaged the click mechanism twice and warped the bezel itself that second time, the aluminum insert survived without a scratch. I know a ceramic insert would've also been toast probably both times. Do I like ceramic? Yes, matte ceramic the most. I have a few watches with ceramic inserts. I just don't think we should pretend it's the best for purpose or the toughest material you could choose. It looks very, very nice. I also don't think we should be insistent on it. I hate reading, "It should have a ceramic insert for that price." and endless drivel like that. I try and value a watch as an entire design and package.
If I would have the power of gods, I will push Omega to use this as a Bible:
I think this thread is asking the wrong question. It is not what the influence of the new planet ocean on the 300m is. They are different watches with somewhat different markets and the 300m is one of omegas most popular watches (although the new planet ocean has no doubt been designed to appeal to a broader market then the previous model, and have a bigger sales share of luxury watch sales).
The correct question is what the new 300m will look like based on customer feedback on the old model and watch trends.
We can clearly say that based on customer feedback that the pressure valve is going and that the bracelet will taper and be a lighter design.
Based on market trends, the watch will be smaller (maybe 1mm) and will either be no-date or have a no date option.
Everything else is pure speculation. Will Omega keep the dodecagon bezel and the twisted lugs ? We will see. We have seen that all watches companies are prepared to upset a clique of purists in favour of increasing the appeal to the watch buying public - a smart move. How this will effect the 300m is impossible to say.
No, we can't say this with certainty.
Huh? This is all pure speculation. Omega don't always do what watch enthusiasts expect them to.
The only thing I would bet money on is they slightly reduce the thickness. The new PO is still 600M and yet is now only 0.2mm thicker at 13.8 mm vs 13.6mm for the SMP. The Submariner is 12.5mm. However you land on the thickness argument, those numbers are not flattering to the SMP and given the PO was slimmed down, I'm very confident the SMP will be as well. I have no idea how far they'll go to achieve it though, I'd want them to match the Sub but there's no way they will IMO. Probably around 13.0mm is my guess.
and the new PO is 177g, the 300m is 195g. The new PO is 47.1mm lug-to-lug the 300m is 50mm. The 300m might not make all the innovations of the PO due to the cost. It needs to be a lower price point.
I don't think the new PO has any material innovations in it that the SMP doesn't already. I think they could do everything they've done to the new PO to the new SMP without needing to change the price point. Of course, they will raise the price because they can but they don't need to raise it anywhere near the PO.
Actually the new PO if anything is likely cheaper to manufacture than the old one. No date, no display back, no HEV, less materials as it's smaller, and the new bezel seems to have repeatedly documented QC issues so I'd wager there was cost cutting there but I can't substantiate that.
The new PO is 600m not 300m. It has a titanium inner shell to do away with the helium valve which is a new innovation. It has a 89xx not the 88xx in the 300m which is a more expensive movement.. We can not speculate about the construction of the case for a 600mm diver but I am sure it is more sophisticated then the 300m. There are no issues I have seen with the bezel. I think the cost cutting ideas are completely without any basis, in fact I am sure the case is more expensive to produce then the old version.
The only change I consider a sure thing in any new Omega model is a higher price point. Sadly...
The newest, latest SMP variants went back to brass dials, aluminum bezel inserts, and solid casebacks, but utilized the same overall case design. If the new SMP is designed around those materials, the watch can be redesigned to be thinner overall. The new POs have what appears to be brass dials, interestingly. The current Submariner uses a brass dial.
If the new SMP is this magical "1mm thinner" that will solve everything for everyone, it will have to be a new design.
The modern SMP design exists as it does in order to physically support the material that many customers and dumb YouTube personalities insisted upon in order to make it "premium" and competitive and to move it upmarket. You only have to look as far as the newest (42.5mm) PO compared to the previous generation to see the affect that material changes can make. This also is evidence that Omega can build relatively thin watches and seemingly has a desire to if the features and the material choices support it. It would be extremely odd (Omega can be odd) if they designed a new SMP 300m and it somehow came out to remain as thick as the newest POs.
Omega has averaged a ~5% price increase each year for at least this century. There was a significant stabilizing the year after the first coaxial models were released, but that year was preceded by a significant increase the year before. I'd expect the price to increase by at least that much, probably, very likely, more. Redesign costs more, sourcing new contractors costs more, those contractors will likely be charging more, labor in general has all but surely increased in price in the interim, and there's all the little things we can't even fathom that goes into designing and executing that design. I don't like it, but that's probably how it's going to go.
There is little (if any at all) evidence that the helium escape valve will be omitted from the incipient SMP and absolutely, decidedly, almost damningly zero evidence that the new Bond bracelet will be tapered. Could a new bracelet design be forthcoming? I think there's a greater chance of that, even a chance that a watch that looks similar to the Peter Blake versions could happen.
I know I'm a broken record here and I often sound frustrated. These are my opinions, assumptions and deductions where specific details aren't available, I could be wrong.
The current Seamaster 300 (heritage) weighs 150g.
The ultra deep uses a lot of advanced titanium construction, is part of the planet ocean line, and has not had an external HeV since its creation. The new planet ocean case leans into the UD design (in addition to taking design cues from some '70s Omega divers, and let's not forget that the planet ocean has always been a successor to the 165.024 in terms of dial and case elements)
My assessment exactly.
I do think they went a bit too far with the architectural angles, but I think I understand where they thought they needed to go with the PO.
After all it started out as something with the version 1 of the PO and progressively morphed it in the same direction into something that didn't make any sense or have any logic at all behind it from an end users perspective.bit became a mere curiosity occupying another space in the display cabinets.
I'm not sure they were selling all that well either.
I think Omega knew they had to do something to prevent it from potentially becoming extinct.
This 4th generation is a desperate attempt to reinvent the PO and loop back to Omega roots in the process.
Getting rid of the wart was inevitable.
The UD is a prime example of the redundancy of the wart. Keeping the wart is a retrograde step altogether.
After all, Seiko have never needed it.
Just my 2 cents worth and I'm all in on the gen 4.
I think this is exactly why they will keep the HEV on the SMP, ultimately. That's a watch that is full of design quirks- scalloped bezel? No-taper bracelet? Skeletonized hands? HeV? All of these things make it distinct and instantly recognizable, if you start taking away from this you wind up with something much more generic.
Makes a lot of sense with the planet ocean, leans more into the 165 design that the first gen PO was already pulling from.
The Seiko is in an entirely different design class, follows an entirely different design philosophy and exhibits but a single solution to the helium gas issue. I can only imagine the lamentations today if Omega had designed a similar huge watch in the 1980s and people watched it getting larger, and larger as premium features and materials were added over the decades. 0. 1mm, 0.5mm, lol! Can you imagine! The HEV was a design choice, a necessary one given the engineering and design constraints that Omega was operating under at the time.
And I think most significantly, it doesn't prevent the watch from selling. Some people hate it, but Omega sells the heck out of the SMP.
I do agree but don’t think that the PO is desperate at all. The old PO was a cult watch for men with thicker wrists. Omega wants a 300 desk diver and a deep/proprof ridiculous. The 600m is a class that sits in the middle. It is tougher and better than the 300s but wearable as a daily wearer. The PO is a new range from 2005 and has no heritage. The new PO is the best ever as it is much more wearable . It will never sell as much as the cheaper 300, but I predict it will sell much more then the old PO. Rolex fundamentally changed the deep sea and went from 40mm to 43mm and no one cried. Omega has done the opposite and shrunk. A much better idea. I think the style of the new PO will be around much longer then the old PO
Chronologically it is a successor to the 2254.50. From a design standpoint,the first gen takes a lot from vthe 166.024 (60s SM300) and the 2254.50. Other than the helium Escape valve, it has almost no other commonality with the Seamaster professional from the same time period. The case, bezel, dial, and hands all differ significantly.
Kinda. The first gen PO (2201.50) has a ~40mm bezel diameter and 47.7mm lug to lug and 14.2mm of thickness with a domed crystal. if you convert the domed crystal to a flat one like the current Planet ocean has, you're in the High 13 mm range for thickness.
So---- the current gen is really, really close to the first gen PO in dimensions. The dial/bezel diameter is around half a millimeter larger, and the asymmetrical case is comparatively about 0.5mm less aggressive.
